Results 1 to 19 of 19
Thread: What do you pay for closing?
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    This is our first year with a pool, so I'm starting to look into closing options. Local companies are all quoting me in the $500 range, which I think is a bit high.
    I read the pool school closing article, and it all seems mostly straight forward except for blowing out the lines. A local company will do a line blow-out only for $136.
    So I guess my options are:
    A) Pay $500 per season for full service closing
    B) Pay $136 per season for blow-out and do the rest myself
    C) Get a Cyclone and learn to do it all myself
    Any suggestions? I know a lot of you probably DIY the whole process.
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Re: What do you pay for closing?
    For my first closing, I watched and asked the pool company lots of questions so I could learn how to close properly.
    I closed it myself one year (without anyone else helping me) and ended up bursting an above ground pipe... luckily my heater and below ground plumbing was okay. Thankfully my son was in town and able to repair the pipe.
    To avoid any problems, I'm back to having a pool company close it for me at a cost of $400 (Washington DC metro area prices). I always add extra polyquat60 since they never add enough.
    I'm middle aged single female and I don't have the strength to do everything, but if I was a few years younger I would close it myself.
    For some, paying a pool company to close is good insurance to protect yourself from costly repairs of burst pipes or broken equipment.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    dw9000's Avatar
    Aug 2014
    NW Ohio
    184
    $350 is what the going rate here in the NW ohio
    In-ground block / vinyl liner 33' x 22' x 5',, approx 25k gals
    Cartridge Filter
    Floor drains, 2 skimmers, 3 return lines (2" plumbing ultra-flex PVC)
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Kcindc : For my first closing, I watched and asked the pool company lots of questions so I could learn how to close properly. I closed it myself one year (without anyone else helping me) and ended up bursting an above ground pipe... luckily my heater and below ground plumbing was okay. Thankfully my son was in town and able to repair the pipe.
    What pipe exactly burst and how did it come apart? Blowing air through the system and having a pipe burst above ground sounds kind of strange. What type of air compressor were you using? Maybe you closed off a valve and pressure built up. When closing a pool, the main drain should stay open to protect the system and it is always the last to go, so the system does not build to much backpressure. Just curious. I am glad that you were able to fix it.
    Pin Guy, I would recommend paying the $136, if you are not comfortable, as this is a fair price for the lines only. Keep us posted!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Aug 2014
    Northern IL
    4,615
    Northern IL:
    auto-cover/no cover $420
    solid w/ straps $530
    solid w/bags $570
    mesh $485
    chemicals extra so you can do chems yourself
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Wow, for the first time it looks like I'm getting a deal here in ny, $300 with a LoopLoc cover.
    They ask me to lower the water to about a foot below the tiles and they do the rest.
    Another $300 to open.
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Aug 2014
    Northern IL
    4,615
    EV: There are some other alternatives, but that company has an absolute guarantee on equipment and plumbing. Cheapest I know here for your type of cover is $375.
    Ping: $136 seems like a great compromise!
    jccams's Avatar
    Dexter, MI
    95
    I pay $275 which includes installation of my loop-loc cover in SE MI. I take care of balancing the chemicals myself.
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Quote Originally Posted by Catanzaro View Post
    It was the pipe between my heater and my in line chlorinator. It failed because i used a leaf blower which didn't have enough pressure to go through the pipes and equipment. It was enough to get the water out of the heater but after the heater the pipes dip down below the rest of the equipment before coming back up to the chlorinator.
    If I did it myself again, I would purchase a compressor.
    Karen
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Last year I had the pool company blow out my lines, RV antifreeze and air lock the main drain. Before they arrived, I had lowered the water level below returns. I handled installing the loop-loc cover after closing. Based on a CYA rise I measured in the spring, they added some dichlor during closing against my wishes. I'd have to look up the receipt but I believe it was $120. I'm debating about doing the blow-out myself this year but that $120 is kind of cheap insurance if anything should go wrong over the winter such as freeze damage...
    Isolated Spa - 345 Gallons
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    154
    Wow...I think I need to open a side business with those rates! I did my own last year as a first time pool owner. Yes, I was worried b/c of no prior experience, but I am also the "I'd prefer to do it myself type", even though it probably took me 3x as long as someone who has done it for years. Good luck with whatever you decide!
    Sent using Tapatalk
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    Jun 2014
    Rogers, AR
    427
    I pay $149.00. They close and put the loop loc cover on. I do my own chemicals otherwise they charge $16.00 for chemicals.
    Opening, they open, make sure everything is working and put the cover away. I do my own chemicals and they charge 149.00 plus, if I open in March they give me a $50.00 gift card for their company.
    16x32 IG rectangular 21,800k new vinyl liner 2014, Triton II TR 50 sand Filter, Pentair 3/4 hsp whisperflow pump, 3 returns, TF100 test kit w/speedstir. Maytronics s 300i robot.
    Aug 2014
    Northern IL
    4,615
    Sweet deal. Our prices are high because we are in an affluent area. (Not us...!!!) And there's not enough competition. There are tons of pools, most everyone has them.
    Casey's Avatar
    SW PA
    10,450
    Quote Originally Posted by pinguy View Post
    Since this is your first year, maybe you can SLAM the pool, lower the water and pay the price for the education on actually closing your pool. You may be able to negotiate a lower price if you can help. You won't know if you don't ask. Good luck! I just closed my pool by myself but I have an above ground.
    May 2013
    Fort Lauderdale, FL
    423
    $300 for mine. I watched closely on the first closing. It was so easy. I noted what model of air blower they used and bought my own (cyclone, $300). Now I do my own closings.
    You can lower the water yourself, bring it to slam level, throw a $15 bottle of 60% polyquat, and call the guy who will blow the lines for $136, or just buy the cyclone. I did.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Bosqueboy's Avatar
    Oct 2007
    Amherst, VA
    45
    I'm paying $220 without chemicals or $290 with. I choose to do the pre-closing cleaning and add the chemicals myself. At $220, I feel like I'm getting a bargain.
    Bosqueboy in Virginia
    In-ground 20,000 gal vinyl Grecian, Hayward Star-Clear Plus C1200 cartridge filter, Hayward 3/4 HP Superpump, AquaRite salt water chlorine generator, Heat Siphon C575HP heat pump and Blue Diamond robotic cleaner.
    ned8377's Avatar
    Apr 2015
    Wake Forest, NC
    242
    I pay $250. I put my own chemicals in. Have a loop loc cover.
    True L 45,000 gal Hayward IG vinyl pool. Hayward Tristar 2.40 THP; 1.5 FRHP/1.60 SF. Hayward Model # S310T2 Sand Filter. Aqua Rite T-15. Aqua Comfort 154,000 BTU Heat Pump. TF-100
    Aug 2014
    Northern IL
    4,615
    One of these days we will close our own. I could use the savings!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Wow, I thought we were paying a bit much for 20 minutes work, three plugs and a couple gallons of RV antifreeze. We are only paying 150-175 but I still want to get a "Cyclone" and close it myself. I've seen it done enough times I'm sure I can do as good a job as the guys we get out here if I had the proper blower. That blower is the key. It's a bit much $$$300 to purchase initially but it pays for itself the second or third year. It's just spending that much for something you use once a year !!!
    Anyone with a recommendation for something that works as well but isn't three hundred bucks ??
    Solar Blanket, Well Water, Borax Added. 68
