Thread: Weir Door Stop Repair
    Feb 2013
    Delaware
    15
    Hi everyone. Discovered a bit of an issue this morning when I checked my skimmer. The plastic piece at the top of my skimmer opening that holds the rubber stopper that prevents the weir door from floating back out toward the pool broke off. Pool is an in-ground gunite pool about 14 years old or so. Looks like the plastic just got old and snapped off. It's an American Products/Pentair skimmer unit. Does anyone have any suggestions on the most effective way to re-attach/repair this piece short of jackhammering out the entire skimmer? My guess is some type of epoxy should do the trick, but obviously, it has to take the constant pounding of the weir slapping into it on a daily basis. It's above the water line, so making a "dry" repair won't be an issue. I look forward to your suggestions and advise.
    Thanks!
    18'x40' free form 24,000 gal. IG white plaster pool, Pentair Intelliflow VS pump, Pentair FSN 60 DE Filter, Pentair UltraTemp 120 Heat Pump, Pentair Easy Touch control system w/IC40 SWG , Flo-Vis flow meter - built in 2000.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Weir Door Stop Repair
    Just spit-balling here but here's my idea. Drill out a hole or use a self tapping screw to attach a rubber foot in the proper location on the top of the inner skimmer channel. A foot similar to these, but in a size that suits you. Once screwed in, coat the screw head with some silicone caulking if you don't go with a stainless or bronze screw. Might be difficult to get tools in the skimmer to do this though... In that case maybe try to epoxy the rubber foot directly to the top of the skimmer channel. Not sure if the epoxy or continuous pool water exposure would break down the rubber though. Or just epoxy a plastic piece that will do the job.
    Isolated Spa - 345 Gallons
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    I'll spitball another idea albeit a pricier one than JVTrain suggested.
    Find your skimmer online hopefully with a blown-up diagram of all its parts and see if there is any kind of a replacement piece available. You might have to buy a new skimmer but perhaps cutting a new one down and marrying it with your old one might be of value...or not.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    Why don't you look at getting a new basket and a circular weir? You won't need the door at all
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,734
    Something like THIS
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    Jun 2015
    Wildomar, California
    423
    I'm. A KISS guy. I screwed a SS screw into the side of the skimmer throat wall that is above the water line. It has worked well.
