Thread: Closing question
    jbriggs1219's Avatar
    Apr 2015
    Brunswick/Ohio
    77
    Closing question
    Since I don't drain my agp...I use a skimmer cover....would it be ok to clean and vacuum pool now and put my pillows and winter cover on now while the water temp is 70ish...continue to keep my chlorine and ph in line and run pump until water is consistently 60 or lower...and then pull cover back a little and follow the agp closing procedures and disconnect equipment and plug return line....is there any harm/risk in doing this?...I'd rather vacuum and cover now while temps are still decent....thoughts?
    13,500 gallon AG
    Cartridge Filter
    Raypak Natural Gas Heater
    Jun 2014
    15,119
    Re: Closing question
    That should work fine.
    Apr 2015
    Brunswick/Ohio
    77
    Thanks I hope so...covered it tonight...lol
    13,500 gallon AG
    Cartridge Filter
    Casey's Avatar
    SW PA
    10,444
    I'm right next door n put mine to bed. Even with it warm during day, it will be fine come April.
