Results 1 to 10 of 10
Thread: How many gallons really?
    tdp's Avatar
    Sep 2015
    Suburban Philadelphia
    57
    Question How many gallons really?
    Talk about newb questions
    The literature for my pool lists it as 18K gallons, but we were told by the builder that that measurement is when the pool is filled to the very top (which it never is). Do I use 18K gallons for the purposes of pool chemistry? If not, how do I know how many gallons to use? If it helps, when the pool was filled for the first time, they said it took exactly two 7K gallon truckfuls, but I don't know how accurate that is.
    Thank you!!
    tdp
    ~17,500 gal. IG Fiberglass, Viking "Cambridge"; installed 6/2015
    SWG Hayward Turbo Cell T-9
    Hayward Hi-Rate Sand Filter
    Hayward Max-Flo XL pump
    TF-100 Test Kit/SpeedStir
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: How many gallons really?
    Start with a number you feel is close and add chemicals based on that number. If you find that the chemical additions are NOT turning out to be what you thought, adjust your volume of water up or down when you do Pool Math.
    Let's say you use 15k gallons and your pH is at 8.0 when you measured with your TF-100 or Taylor K-2006 test kit. Now you want to take it to 7.2. According to Pool Math, you would need to add 38 ounces of 31.45% muriatic acid to go from 8.0 to 7.2. Let's say you do that and you measure 7.0 with your kit an hour later. Well now you know right away that 15k gallons was too high. Adjust Pool Math to 10k gallons and you'll see that it takes 38 ounces of MA to take a pH of 8.0 down to 7.0.
    You can do this with your FC measurement using the FAS/DPD test as it is quite a bit more accurate than measuring the pH. The above was just an example.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    Jun 2014
    15,212
    Yep. Chris gave a good example of how the Poolmath calculator can work for you. Also, another Viking owner. 2nd one I've seen today. Welcome to TFP!.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by Agent99 View Post
    that is the right idea, but don't use pH for confirming, use FC. pH calculations are tough to use since its hard for pool math to calculate/determine exact pH changes, AND the pH scale is tough to determine between levels since its color based, AND pH is not linear in nature. FC is a good way to judge, plus you are doing additions regularly
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    tdp's Avatar
    Sep 2015
    57
    I have a SWG, so don't do regular chlorine additions...but I agree about the pH being hard to judge.
    Jul 2015
    Western NC
    115
    Quote Originally Posted by tdp View Post
    Having an SWCG doesn't mean that you can't add chlorine.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    tdp's Avatar
    Sep 2015
    57
    I meant I don't normally add chlorine except to SLAM.
    May 2012
    Montville NJ
    545
    Right, but you CAN add chlorine to measure your volume.
    Make sure your SWG is off (and will be off for an hour or two) - towards the evening or on a day with little sun would be good too. Measure your FC, add a measured amount of bleach (say 4 cups - that should be roughly 1 ppm of FC), circulate for an hour or two, and then measure your FC again. Use the calculator to calculate your volume. (you know two of three variables - amount of bleach added and your FC rise, you can now calculate your volume).
    The added 1 ppm or so of FC is not going to hurt anything, and your pool will quickly settle back to normal day to day levels.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
    JoyfulNoise's Avatar
    May 2015
    13,246
    Another way to do it is to use TA. TA changes very slowly in water and is only consumed if you add acid. Although, in the case of TA, you need to add enough baking soda to raise it by 20ppm and you probably want to use a larger test sample size to get more precision (+/- 5ppm/drop). Here's what I would use to do that -
    50mL water sample size
    3 drops of R-0007 (4 drops if the colors don't come out right)
    8-10 drops of R-0008 Indicator (exact indicator amount is not critical it just depends on how much color intensity you need)
    Add R-0009 for a precision of 5ppm/drop
    You can then put your pool volume guess into PoolMath, figure out how much baking soda you need to get an increase of 20ppm (I'd pre-dilute it in a bucket of water and add it to the skimmer so that it circulates quickly, and then wait an hour or two (spend the time brushing your pool for extra cleanliness). Finally measure your TA rise and, if it's off, adjust the pool volume number until you get the TA rise you measured. It's a bit crude because the TA test is not very precise, but it avoids the problems with chlorine getting consumed and having to do the test at night. You can add a greater amount of TA if you have the room to do it and you want to count more drops, but it just means adding more acid later on to lower it back down.
    Matt
    Jul 2014
    Sacramento, CA
    241
    Quote Originally Posted by phonedave View Post
    -dave
    Beware though that chlorine/bleach may not be exactly at the percentage on the bottle -- I'm pretty sure some of the 12.5% jugs I get at the pool store are closer to 15% when really fresh, and after sitting in a store or at home for a while could be significantly lower than 12.5% also. So you'd have to measure the chlorine concentration in a known volume of water (which is hard to do accurately) to be sure.
    But as others like to point out, we aren't making rocket fuel here, so treating it as 15k vs 18k gallons isn't going to make a big difference day to day. I suspect most of us don't really know our pool sizes closer than ~15% (I know I don't). In your case, since the builder indicated that it definitely isn't 18k to the normal fill level, I'd just use 16k as a "close enough" number. You could measure the surface area, multiply by the depth from the deck to the surface of the water currently, and see how many gallons that comes to (7.48 gallons per cubic foot).
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
