Thread: Time between swim ability and closing
    bryansanders's Avatar
    Jul 2015
    Green Country, OK
    70
    This is what I am going to do until the water reaches 60 degrees...keep FC up and vac when needed. Keep cover on (to keep out leaves, etc.) until time to test or clean. Once water temp is 60, follow AGP Closing procedures...drain to proper level, plug return, drain hoses/filter, remove pump and filter? for storage. Cover and wait til Spring.
    Does this sound about right?
    Aqua Leader 33' x 54" AG, 28+k, AquaTools 2HP 2SP pump, AquaTools 200lb Sand filter, Liquid Chlorine, TF-100
    Installed 8.1.15, rural water, direct sunlight 8hrs/day, Aquabot Breeze XLS
    Jun 2014
    15,259
    Re: Time between swim ability and closing
    That about covers it.
    rdshackleford's Avatar
    Jul 2015
    Coatesville, PA
    116
    You forgot, before and until you cover, go in for a short swim and act like you enjoy the water that cold. That is what I do.
    29,085.1 gal inground grecian vinyl, Hayward Super Pump VS, Hayward S-240 sand filter, Dolphin Nautilus Plus (aka Agador Spartacus), Taylor K-2006 kit, nice pool brush, crappy leaf net, frogs
    Jun 2014
    15,259
    Polar dips! Burrrrrrrrr!
    Apr 2015
    South Central PA
    298
    Is there any benefit to removing the solar cover at night to cool faster and cover during the day to prevent chlorine loss? Or is the ground surrounding the pool going to keep the water temp up to the point where it's not worth the trouble?
    20000 gallon vinyl liner in ground pool
    16' X 34' rectangular diving pool
    Hayward Pro Grid DE Filter
    Hayward 1 hp Super Pump
    TF-100 Test Kit Stenner 45MPHP10
