I just put in a 24ft pool and need to run the electrical to the pump. The pump has a twist lock plug, so I will be putting a twist lock recepticle near the pump. I am going to run 12-2 UF-B w/ ground wiring from a dedicated 20amp GFCI breaker in the house to the twist lock outlet. No need for any other lighting or electrical needs.
The breaker box in the house is just on the other side of the foundation in the basement which is maybe 10-15 feet from the pump. I will drill a hole in the foundation to run the wiring out and then underground to the pump outlet box. My question is what should I do on the house where the hole is in the foundation? How do I properly cover the wiring as it comes through the foundation and then heads underground? I know I can get some conduit to cover as it runs down the house... but what goes on the house/foundation itself where it comes out?
Thanks
Thanks
