Thread: Dolphin Wave-100 does not climb walls
    Sep 2015
    Greece
    25
    My brand new Dolphin Wave 100 pool cleaner has a hard time climbing the walls to clean the waterline. Specifically, it looks like out of 20 efforts it may manage to climb the wall once. I am certain that the filter is clean because we clean it essentially after every use.
    The local distributor has thrown an idea that the reason may be a thin biofilm on the walls (algae precursor??) that makes the walls slippery (the pool water is otherwise crystal clear)
    Does that explanation hold any water?
    Let me also add that a different pool cleaner from Astral that we tried, did not have any problem climbing at all.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Re: Dolphin Wave-100 does not climb walls
    If your model has float devices on the handle, try adjusting them outward, and try angling the handle. Then drop the dolphin in the water upside dwn to ensure there are no air pockets and see if that helps.
    I have the M4 Supreme model, and it climbs walls like a champ. But I've heard of others who need to make adjustments to achieve this
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Sep 2015
    Greece
    25
    Quote Originally Posted by Swampwoman View Post
    How often does M4 climb the walls? Everytime, or once every xxx minutes?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    That seems to deend on where it starts in the pool...it kinda just follows its own path, but when its done it hasn't missed anything
    Helpful Links:
