Thread: Leaf cover
    Aug 2011
    Western NY
    6
    Leaf cover
    We just broke down this spring and bought a heater for the pool. Now is the time we usually close (Buffalo, NY) but with the heater I would love to leave it open until October. The problem is the ongoing leaf struggle... We use a winter mesh cover so I don't have any experience with them. I'm curious if they can be placed over the solar cover and are they "relatively" easy to take on and off? We have a 18x36 inground oval shaped pool. I'll take any suggestions, thanks!!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    Re: Leaf cover
    It sounds like you're in just the same boat as I am in. We're using the solar cover to try to help the heater keep the water around 82 and the leaves are quickly taking over. We use the Leaf cover right over the solar cover just as you are saying. It does add a slight bit of work to remove, but not nearly as much as cleaning off the leaves from the cover. My 5year old daughter and I remove the covers and while some of the smaller debris does end up in the water, the majority is caught by the leaf covers.
    Aug 2011
    Western NY
    6
    Re: Leaf cover
    Thanks so much! I think we'll give one a try, we have 2 daughters that want to keep swimming so I'm sure they will be more than happy to help
