Thread: Goldline solar control in AGP
    Jul 2008
    Solon, Iowa
    170
    Should I wire my solar controller (Goldline 235) to be powered by my pump timer (AquaTrol panel) or can I leave it powered all the time, since the 3-way valve position doesn't matter when the pump isn't running?
    Kelly
    15X30 AGP, Lomart beaded liner;
    1.5 HP Sta-Rite pump with 21 inch sand filter (Zeobrite media)
    Mineral Springs (Aquatrol) SWCG, Rigid PVC plumbing, 2 inch
    Four 4X12 Techno-Solis solar panels, rack mounted, Goldline Solar Controller
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Goldline solar control in AGP
    Bueller?
    I don't think that it matters very much unless you have the GL-235-LV-HV model. The GL-235-LV-HV is designed to over-ride the pump timer and turn the pump on when there is heat available and the pool needs heat. For that to work it has to be wired directly to main power.
    Jul 2008
    Solon, Iowa
    170
    Thanks, I believe I have the LV-HV, but since I live in Iowa and open/close well after/before freezing temps I hadn't planned on using the pump override option for freeze protection via recirculate.
    I'll see if I have power lugs inside my Aquatrol that I can tap.
    Kelly
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Quote Originally Posted by kjcole
    The recirculate isn't only for freeazing. It will turn the pump on automatically whenever the panels are able to produce heat.
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
