Results 1 to 18 of 18
Thread: Flow Meter
    May 2008
    Marana AZ
    45
    Flow Meter
    Here are some photos of my equipment. Where would the best place to put a flow meter?
    If I start the pump at full speed and back the RPMs down until the flow rate starts to drop. Is that the most efficient RPM for the pump to run at?
    13,000 gallon pool and spa, StoneScapes mini pebble midnight blue, Ecostar VS pump, Tristar VS pump for water fall, Hayward SwimClear C4030 filter, Hayward H400FDN heater, 9 4x12 Heliocol solar panels, paramount PV3 in floor cleaner, Omnilogic , T-15 salt cell, sense and dispense
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Flow Meter
    Wow, that is a tight squeeze! I don't think I would try to get a flow meter in there. It really doesn't tell you much. You want to have enough flow to to make your SWG happy and not get a low flow error and enough flow to skim your pool surface. For my VS pump I started at 900 rpm but got low flow error as the filter got dirty, tried 1000 and it was better but still got them occasionally. Ended up at 1100 rpm which uses 150 watts, never gives me a low flow error and does a good job skimming the leaves.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Flow Meter
    Well, if you had a Jandy style check valve, you could easily put in a TFTestkits.net as show here. I have the one on the upper right.
    ----Chris----
    25k IG/Spa Figure 8, 18x36, Pebble Sheen Blue Granite, Sta-Rite S8M150 Cartridge Filter, Pentair 460805 400k BTU Heater & 011018 IntelliFlo VarSpd
    Liquidator, Fafco Solar Heat, Polaris PB460 Booster Pump w/280 cleaner, Katchaleaf Cover, TF100 Test Kit, FAKE MAIN DRAIN
    May 2008
    Marana AZ
    45
    Re: Flow Meter
    I think I am going to put it right after the pump. If you look at the third photo it will be in the horizontal PVC pipe just over the pump basket.
    May 2008
    Marana AZ
    45
    Re: Flow Meter
    Anyone have a suggestion were to put the flow meter?
    38,301
    Re: Flow Meter
    Why do you need a flow meter? Do I recall from another thread that you are adding solar?
    You last question makes no sense as the flow rate and pump speed are related. The flow rate will always drop as you lower the pump speed. The most efficient speed is down around 1000rpm, but that is often too low for some applications.
    May 2008
    Marana AZ
    45
    Re: Flow Meter
    My signature states 9 solar panels. I am installing 6 more next week so I will have 15 panels.
    Wont the flow rate max out at a certain RPM. If you run the pump over that RPM the flow rate stays the same but the power consumption increases. That makes me think that if you start at full speed (RPM) you be at the max flow rate. If you decrease the RPM a little at a time until the flow rate drops you can determine the most efficient RPM. Is this correct?
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Flow Meter
    I have a flow meter that I installed when I added the VS pump. I referred to it a bit at first in setting up my pump programming, but never look at it anymore. As far as the solar panels I just set my pump a few hundred rpm above the minimum required to keep the air relief valve closed. That seems to work well for me.
    I have 12 4x12.5 Heliocol panels on the roof and when the solar heat comes on the pump Ramps up to 2,400 rpm (750 watts). A local Heliocol tech was here recently for a leak, and confirmed that setup was working fine.
    chiefwej
    38,301
    Re: Flow Meter
    Within the limits of pool pumps, the flow rate will change with any rpm change.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Flow Meter
    Quote Originally Posted by booboo View Post
    No, this is not correct. Flow rate is directly proportional to RPM. There is no fundamental limit to flow rate through plumbing. The max flow rate is determined by the pump head curve and the plumbing curve cross over point.
    Mark
    May 2008
    Marana AZ
    45
    Re: Flow Meter
    Quote Originally Posted by mas985 View Post
    The pump I have is a Hayward EchoStar VS 3400. I was told that this pump will operate more efficient at a lower RPM than full speed. I was also told that using a flow meter will allow me to determine the most efficient speed. Is this not true?
    DFW, TX
    24,497
    Re: Flow Meter
    It is true that it will be more efficient at lower speed. Most 2 speed pumps move 1/2 the water volume using 1/4 of the power on low vs high speeds. The same curve applies to VS pumps although I don't know the ratio. Gallons pumped per watt will be higher at lower pump speeds.
    My VS pump moves plenty of water for skimming and making chlorine at 1100 rpm and only uses 150 watts of electricity. For solar it runs at 1950 rpm and moves substantially more water and uses 550 watts. At 2500 rpm is uses 1150 watts. It does not seem like it pumps twice as much water at 2500 rpm as it does at 1950 rpm even though it is using twice as much electricity.
    Yes, I do suppose if you had a flow meter you could set up a spreadsheet to calculate the most gallons pumped per watt to determine the most efficient pump speed. But, that seems like a lot of effort when that flow rate might not be right for your application. And gut feel and low flow sensors for heaters, SWGs, etc will get you close enough. For solar you want your panels to be relatively cool to the touch and the water coming in to the pool not to be too warm. The cooler the panels are to the touch the more heat the water is transferring and taking to the pool. This is more important than a certain gallon per minute flow rate or a certain pump efficiency.
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Flow Meter
    pooldv, How did you figure out at what rpm to run your solar? 1950 rpm is kind of specific sounding.
    ----Chris----
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Flow Meter
    Yes the pump will operate more efficienty at low speed but I was commenting the following that was not true.
    Wont the flow rate max out at a certain RPM (yes full speed). If you run the pump over that RPM the flow rate stays the same(No, flow rate continues to go up) but the power consumption increases. That makes me think that if you start at full speed (RPM) you be at the max flow rate. If you decrease the RPM a little at a time until the flow rate drops you can determine the most efficient RPM. Is this correct?
    The most efficient speed for the EcoStar is around 1000 RPM.
    Mark
    Sep 2015
    Sewell, NJ
    3
    Re: Flow Meter
    Id have to agree with the guys on this, you have very little straight run, flow meters to be accurate typically have to have a certain ratio of distances before and after an elbow. For a 1.5" pipe is like 15 or sixteen inches before and like 6-8 inches after depending on the manufacturers guidelines. Ignore this and you wont get anything or at least anything accurate. Also should be on the return side of the filter. If you had influent and effluent pressure gauges at the pump, you could use the pump curve of your model to determine your flow. A summer club in consult for has to do this on their baby pool and I had to get permission from the health department to use this because of the situation.
    Chris Miller
    Aquatics Director, GCIT
    700,000 Gallon 50Mx25y ;Indoor Competition facility
    Neptune Benson Defender DE filter (perlite)
    50hp Pump on a VFD, UV system, Pulsar 4
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Flow Meter
    FlowVisŪ Flow Meters do not need long straight pipe runs (unlike other flow meters). See Section 8 Installation in this manual showing that it can be installed right next to an elbow since it is not affected by flow stream disturbances.
    DFW, TX
    24,497
    Re: Flow Meter
    Quote Originally Posted by Agent99 View Post
    Well, it isn't 1956! like that other thread! I was just upping it by 50 rpm until it seemed good and that is where it landed. I get good solar heating and low power consumption! Double winner!
    Agent99's Avatar
    Aug 2008
    San Jose, CA
    688
    Re: Flow Meter
    Quote Originally Posted by pooldv View Post
    About the only thing I could tell with my solar heating was that running it at around 2000 rpm, the returns were noisy and bubbly and that just didn't seem right. I think around 2200 they quieted so I set it at 2300 and called it good. Are your panels on a second story roof? Mine are. It is probably getting close to 30 feet to the top tube of the solar return pipe. Looking at various pump curves for the IntelliFlo 011018 and using 30' of head, 2000 and up looked like a good region to run my pump at. Also, my filter gauge reads about 15 psi (clean cartridges) at this 2300 clip. It was recommended to me by a Pentair tech to run the pump at that PSI for solar panels on a second story roof so it all seems good. When I close off the pool (no solar), he said running it at 5 psi should be plenty. That comes out to around 1500 rpm last I checked for my system.
    Quote Originally Posted by chem geek View Post
    This flow meter is a bit spendy but it is dead simple to install assuming you have a Jandy check-valve. As Richard posted, they can be installed anywhere you have a check valve. Pretty slick little device.
    ----Chris----
