Results 1 to 7 of 7
Thread: Tire Tube as Air Pillow
    Jun 2011
    New Berlin, WI
    48
    So I'm tired of buying Air Pillows just to not have them last the winter so this year I'm using a tire inner tube, Amazon should have it here on Thursday. I'm assuming the same thing should apply like the air pillows...don't inflate it 100%, just 50-75% full. Any thoughts
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Tire Tube as Air Pillow
    Make sure the valve does not hit the cover. I would think it would work?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    Might make the water smell funny? I think some monomers will leech out a little over the winter.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Snow is not an issue for me. But I think I would have bought an inflatable raft instead. They're designed for constant immersion and are made out of pretty much the same material as intex pools.
    Jun 2011
    New Berlin, WI
    48
    Quote Originally Posted by EVChargeGuy View Post
    That is what I planned on doing
    Quote Originally Posted by pabeader View Post
    as long as it smells like pool water after I start putting bleach in the spring. What are monomers and should I be concerned?
    Should have waited to press Checkout till later today... could have bought a raft!
    oh well, if my partner gets his way we won't be at this house next spring so any problems won't be mine
    Thanks for the replies though! This site has helped a lot even though I barely use the pool (think I was in it but 2 times this season)
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    monomers are the things that make rubber stretchy. They make your hands smell funky when you hold on to an inner tube. Not an issue, just a thing to remember for next year.
    Jun 2011
    New Berlin, WI
    48
    Well I'm happy and sad to report that we are still here, and I just opened the pool and No funky smell from the tire tube and the tube stayed inflated unlike the air pillows I buy each year.
