Thread: Pool Pilot Nano+ question
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    575
    Question on my PP Nano+ SWG. If I reset the % output on the panel to lower the output, does it automatically adjust the % to compensate for water temps?
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    Ft Lauderdale, Florida
    1,455
    Re: Pool Pilot Nano+ question
    Yes. It always temperature compensates. When it drops below 70 degrees water temperature, you may see some limits on how high you can increase the % setting. As it drops to 55 degrees or colder, it will not allow you to go higher than 1%, but at least it will continue to generate a minimal chlorine residual.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
