Results 1 to 8 of 8
Thread: Stenner tube replacement
    Sep 2014
    North DFW
    161
    My Stenner pump stopped pumping chlorine into my pool, and I discovered a small crack in the tube. I went to replace the tube with the spare that came with the pump only to find out that it was about 3/8 to 1/2 inch shorter that the cracked tube. I couldn't expand the roller assembly to make the tube have tight contact with the outer housing. I ordered 2 new tubes, hopefully I won't have any issues with them. Has anybody else experienced anything like this?
    Thanks
    39' x 18' IG 3.5X4.5X9 34k gallon w/ raised spa, 3 stone scupers
    Jandy 60 SqFt DE, Jandy PDA PS6, Jandy JXi400 heater, Jandy 2.0 EPump w/SVRS
    A&A Manufacturing ICS w/G4 venturi heads
    2 incandescent lights in pool, 1 in spa.
    Dec 2011
    Prosper, Texas
    124
    Re: Stenner tube replacement
    i replaced mine today because it stopped working as well. Are you sure you can't stretch it to fit? did you try turning the pump on when installing the tube?
    21,000 gallon pool w/spa, Pebble Sheen, Hayward EcoStar variable speed filter pump, Hayward DE6020 Filter, Hayward 400FDN Heater, Stenner pump with 15 gallon tank, Clear O3 ozone system, Hayward Goldline PS-8 controller, Hayward 6060 cleaner pump, Polaris 280 cleaner, Hayward EcoStar variable speed water feature pump.
    Jul 2015
    Central Valley CA
    1,107
    I don't have a Stenner yet but have a fair amount of experience with tubing as a home brewer. I have found that hot water works wonders for tubes that seem too small, try soaking the tube in water about the temp of a hot cup of coffee install it and run the pump while it's still warm, you could even try pumping warm water. If it can be stretched to fit as Cajun suggested that will make the process a bit easier.
    Sep 2014
    North DFW
    161
    Quote Originally Posted by Cajun View Post
    Absolutely, I tried stretching that thing. I even let the pump run for 10 minutes to help stretch it, but no luck.
    Quote Originally Posted by atttech-2 View Post
    Thanks, that is not a bad idea. I will give that a try tomorrow. That pump made me lazy... back to manual dosing for now..
    Dec 2014
    Riverside California
    482
    Check this out, new style pump head makes changing the tube easy.
    http://www.cannonwater.net/Stenner_N...Pump_Head.aspx
    38000 Gal, IG, Plaster, 20' x 40' x 10', Attached Raised Spa, Intelliflo VS 3 HP (011018), Pentair Quad DE 60 Filter, Raypak (Rheem) 400,000 BTU (407a low Nox), Easy Touch 8 upgrade, Screenlogic 2 with wireless, IS-4 Spa Side Remote, Stenner 45MPHP10 w/15 gal tank, Intellibrite 5g (3), Dolphin Triton Plus robot with PRO remote, Water Tech Catfish handheld vacuum for spa, TF100 with SpeedStir.
    22,548
    Those tubes come pretty short, and they can be hard to stretch to fit, but they can be stretched. The hot water idea is a good one and it should help. Just be patient and persistent.
    Sep 2014
    North DFW
    161
    I got the replacement tubes today only to discover they were the same length. After getting frustrated trying expand the roller assembly using tips mentioned above, I noticed a little extra plastic piece in the packaging. After close inspection of the instructions, it turned out to be a fan brake! Bingo. That was it. I could never expand the assembly far enough to lock because the motor was turning. Once I figured out the fan brake, it was easy to expand the assembly. What a pain. Once I got it all back together and turned on the pump, I noticed there was air in the lines. It turns out that the duckbill check valve was also bad. Could that have caused the tube to crack/burst in the first place?
    22,548
    The check valve being bad wouldn't affect the tube at all.
