Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: 2 intake lines
    Jul 2015
    Charter Oak, California
    273
    2 intake lines
    My 12 x 24 x 52 intex pool that we installed in July comes with one return port and two pump intake ports. I believe there is legislation that makes two pump intake ports mandatory. I installed an inexpensive Intex skimmer that clamps onto the top rail to one of the pump returns. For the skimmer to work efficiently, I had to use a plug of sorts in the other intake, per the directions that came with the skimmer. The plug comes with the new skimmer. The skimmer works swimmingly. My question is, if I decide to hard plumb the pool over the winter, do I have to plumb the second pump intake, which is currently blocked? Or can I just cap it off and run one pump return and one pump intake.
    Any thoughts??
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    LFrankow's Avatar
    Sep 2012
    Medicine Hat, Alberta
    502
    Re: 2 intake lines
    The general rule of thumb is to not squeeze the inlet side of a pump, furnace, or boiler, they just work better that way.
    What would I do, look around on Craig's list or Kijiji in Canada for another floating skimmer and implement that into the system.
    Also keep an eye out for a slightly larger sand filter, and a 1 hp pump on sale.
    Intex is notorious for undersized pumps, inlets and outlets to thier pools and equipment, I still use the pools just not the equipment that comes with them.
    Do you have Intex "valves" on the inlets and outlet?
    Lou - 13.5K Gal pool, AG Intex 24 X 52"
    19" Sand Filter/1 hp pump, Aqua Trol SWG
    90 sq ft Homemade Solar panels + 80 sq ft Fafco panels, coupled with a SS heat exchanger/Hot Water Tank, Pentair SolarTouch, Taylor k-2006
    Jul 2015
    273
    Re: 2 intake lines
    Yup. Still have Intex plunger valves. One for the one return line and one for two pump intake lines. The two pump intake lines meet together at the Intex plunger valve. Then out of the valve one single line to the pump. Like a "Y"'. The plug they sent with the skimmer has a small hole in it to allow some flow, however slight. If I hard plumb, I will swap out the two Intex Plunger valves for standard ball valves. So you would recommend keeping the two pump intake lines? In the fashion of a "Y" like it is now?
    And though the pump and filter combination appears to be doing a good job, running 6 hours a day, I will probably upgrade to a 1hp Pump and larger sand filter, as I may add some solar heating in the future.
    Thanks for taking the time.....
    Bob (AKA Schnozz)
    Jun 2015
    Central NJ
    19
    Re: 2 intake lines
    If hard plumbing, might as well do the hayward skimmer mod too. This will increase your flow rate. You could then dedicate one of your intakes to a vacuum port. This would obviously require the use of shutoff valves etc. I have the same pump and filter as you and the hayward works so much better than the stock over the rail skimmer.
    Good luck,
    Greg
    Intex 18 x 52 ultraframe
    1600 gph intex pump w 14" sand filter
    Hayward skimmer mod
    LFrankow's Avatar
    Sep 2012
    502
    Re: 2 intake lines
    So basically you have the same ID going through the pool wall as a single skimmer, as the OP says Hayward thru the wall skimmer should work the best. In your case with an oval Intex pool the skimmer will be at a bit of an angle but can be kept full by raising water level from what I have read. Hayward widemouth is on my agenda for next year actually.
    Jul 2015
    273
    Re: 2 intake lines
    So, if I'm going to hard plumb I should plumb both pump intakes and include shut-off valves for both of them.....obviously, I wil hard plumb the return and incorporate a shut-off valve there too. Just curious if I needed both pump intakes..
    The Hayward was my choice as well. I will look into the wide mouth as well.....
    Bob (AKA Schnozz)
    LFrankow's Avatar
    Sep 2012
    502
    Re: 2 intake lines
    Kind of confused atm you have two holes in your pool for the suction side?
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    Re: 2 intake lines
    I cut out both of my tiny intex pool outlets and installed standard 1.5 inch outlets. Hard plumbed them both. One goes to a 1.5 HP pump and filter, the other goes to the intex pump for a water feature. I did a Hayward through the wall skimmer as well.
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Jul 2015
    273
    Re: 2 intake lines
    image.jpgLfrankow:
    On the left of the pump/filter is the single pump return.....to the right of the pump/filter you can see two pump intakes from the pool going to a single plunge valve then a single hose to the pump, like a "Y" (two into one.). I believe the law requires two returns to reduce the pump intake suction by half at each intake port. So, I should hard plumb both intakes and include ball valves rather than hard plumbing only one of the pump intakes and capping the other?
    Bob (AKA Schnozz)
    LFrankow's Avatar
    Sep 2012
    502
    Re: 2 intake lines
    Quote Originally Posted by philc View Post
    This is the way I would go, increase size and add valves to balance/service.
    Jul 2015
    273
    Re: 2 intake lines
    Quote Originally Posted by LFrankow View Post
    LFrankow: I noticed you plumbed your pool using the Intex plunger valves. Have you had any issues with them. Most of the threads steer clear of those and use standard PVC ball valves. Have the worked ok for you?
    LFrankow's Avatar
    Sep 2012
    502
    Re: 2 intake lines
    The reason I used them was they came with the pool and I had 1 1/2 abs trap adapters to get me to the hard piping.
    The Fernco, trap adapter and valve will go into a warm space soon, will I use them next year, probably as they are almost like a ball valve easy to operate when cleaning pump screens.
    I think the threads coming off of the pool adapter are straight not tapered so I didn't/was too cheap, to find an adapter for that since I already had one that worked.
    After 6 or 7 years I am still almost completely repiping my system every year, replacing pools every second year ( always going up in size ). I try to follow the KISS method when piping, learned after being a plumber for almost 33 years now. KISS = Keep It Simple Stupid
    Jul 2015
    273
    Re: 2 intake lines
    Do you have any images of your set up? I would be interested to see....
    Bob (AKA Schnozz)
    philc's Avatar
    Jul 2015
    190
    Re: 2 intake lines
    I will be happy to take a couple of photos tomorrow and post them.
    LFrankow's Avatar
    Sep 2012
    502
    Re: 2 intake lines
    yeah me three Philc
    philc's Avatar
    Jul 2015
    190
    Re: 2 intake lines
    Sorry for the delay, The flex hoses were added to the hard plumbing to facilitate moving the pumps to their final location next spring.
    I seem to be having difficulty with the upload, will try again later.
    philc's Avatar
    Jul 2015
    190
    Re: 2 intake lines
    Jul 2015
    273
    Re: 2 intake lines
    Your photos show that the newer Intex Pools have 1-return (Far Left) and 2-pump intakes (to the right of the skimmer)...Thanks for taking the time to post them. Good Ideas, clean setup, Crystal Clear water.. Nice work.
    Bob (AKA Schnozz)
    philc's Avatar
    Jul 2015
    190
    Re: 2 intake lines
    It was my pleasure, and thanks!!
  20. Back To Top    #20
    Aug 2015
    Largo, FL
    10
    Re: 2 intake lines
    Schnozz,
    You may want to bookmark this thread. It will show you the parts and the instructions you will need to hard plumb your pool.
    Create intex adapters. Step by step. Lots of embedded photos
    I got most of the part I need now. I may tackle the project this weekend or next weekend. I plan to add the Hayward Wall Skimmer and add 2 additional returns to the pool.
    Intex 24'x12'x52" Vinyl AGP, 8500 gal.
    Intex Sand Filter SF07110 2150 GPH. Intex SWG 15,000 gal.
    Intex Deluxe Wall Mount Surface Skimmer.
    Hayward AquaBug Pool Cleaner.
    TF-100 Test Kit.
