Thread: Reenforcing the Liquidator float assemby.
    Mar 2007
    Virginia Beach
    272
    As I had posted in an earlier thread, at the beginning of this third season with the LQ one of my float assemblies gave out. I noticed that was loose on the container and when I attempted to tighten it down, the threaded post just separated from the float frame. I dissembled my other float and noticed that at that joint the coloration was much lighter than the rest of the float assembly as well. The chemicals just break the plastic down after time. But I think that I have solved it for a few more seasons. I filled the open space inside the float assembly with plastic epoxy. It looks like it will solve the problem. I would recommend doing this at the end of your second season.
    6000 gal inground fiberglass
    1.5hp pump / sand filter
    Liquidator
    Re: Reenforcing the Liquidator float assemby.
    Plastic parts are not normally affected by the chemicals inside the Liquidator. If the plastic is lighter in color near a joint is is probably a weak spot caused by repeated stress. Colored plastic will tend to turn white in areas that are flexed over and over again as the plastic starts to weaken.
    Regardless of the cause, your solution should take care of it.
    krcossin's Avatar
    Detroit Burbs
    113
    I don't understand where you added epoxy. Any pics available?
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
    Mar 2007
    Virginia Beach
    272
    You need to log in to see the picture. There is one attached.
    Liquidator
    I'm going to go with what Jason said. It would have to be stress related. Perhaps overtightened at one point ? Nice way to fix it however.
    ~25k G 20x40 Free form plaster
    Pentair FNS Plus 48 sq/ft DE
    Pentair Challenger 1 HP High Flow E.E.
    Zodiac G4
    8 gal Liquidator 3/8 line conversion
    Sundance Palermo Spa w/ozone and gazebo
    LQ 3/8 Line Conversion
