Thread: Hello from London Ontario Canada
    Sep 2015
    1
    I have a 16x32 salt water pool with a silt problem. New filter 2015. I have backwashed to waste, ran smart pool cleaner, still comes back. Any suggestions on how to get rid of this problem would be appreciated.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Hello from London Ontario Canada
    Welcome to TFP!
    Most of the time, the problem you describe is due to insufficient chlorine. Post your normal FC and CYA levels and we can advise you better.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to the forum!
    Also suggest adding information about your pool and related equipment in your signature. By doing this, it will automatically appear in all your posts so you do not have to re-enter it each time.[/list]
    Here's how to do this: Pool School - Read This BEFORE You Post.
    Not sure what kind of pool cleaner you have, but if there is a fine-mesh silt bag, I would try that. Every couple of springs or so, we get a fine film of silt caused by dust blowing in from West Texas. It's usually not visible in the air but it's noticeable when it lands in your pool. This has worked for me.
