Results 1 to 9 of 9
Thread: Multi-port valve ID
    May 2015
    Lancaster, PA
    7
    Multi-port valve ID
    Looking for assistance in identifying the multi-port valve in this photo. I need to replace it and cannot locate any markings to help me identify it. It is plumbed with 1.5" PVC.
    Re: Multi-port valve ID
    It's a 1.5" Pentair multiport for a de filter. What filter do you have.
    Support the site
    May 2015
    Lancaster, PA
    7
    The filter is a DE filter. Looks to be made by Pentair as well. That's as much as I can tell from the filter since the identification sticker has been worn off by years of weather. Does this photo of the filter help?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Looks like an older Pac-Fab 50 sand filter to me but a filter type would help.
    EDIT: Guess it's a DE.
    Isolated Spa - 345 Gallons
    Feb 2014
    Central Minnesota
    5,080
    Looks like it's from this line of filters: Pac Fab Nautilus Stainless D.E. Parts - INYOPools.com
    There are two replacement valves listed based on piping size. Picture looks like 1.5" so my best guess is you need the Praher Valve,sm W/plumbing 1 1/2 P.f. D.e. (sm1-pp2) - INYOPools.com
    May 2015
    Lancaster, PA
    7
    OK great. Thanks a ton for your help!
    May 2015
    Lancaster, PA
    7
    One other question. Our pool is now closed for the season. Should I wait until the spring to replace this part and another valve on the plumbing? Is there any reason why I can't replace it now? Specifically, in addition to swapping out our multi-port valve, I want to replace a brittle old diverter valve (with a broken grease port knob) with a new no lube jandy valve. This particular valve controls a return on the side of the pool and our sliding board.
    Feb 2014
    Central Minnesota
    5,080
    Have all the lines been blown out and plugged or shut off? If it's fully closed, I wouldn't bother replacing til spring. Just be sure to get the new valve in place before the water gets above 60! Shop around for the best deal until then.
    May 2015
    Lancaster, PA
    7
    Yes, all of the lines have been blown out and plugged. My thought was to replace it now so that it's already off of my plate come springtime. One less thing I need to take care of in addition to getting the pool opened.
