Thread: Hot tub totally empty this morning
    Sep 2015
    Parker TX
    1
    This morning the hot tub was totally empty. Picked up a new check valve but old one doesn't look broken. Automated pool. Pool came with house not 2 years old yet. What else can be the problem? Pent air system.
    Jun 2015
    Wildomar, California
    423
    Re: Hot tub totally empty this morning
    Is it a pool and spa combo? I would suggest you look at the possibility that your system has valve actuators and your system ran on spa suction and drained your spa. Check the micro switch on your suction valve or that it was put into spa suction mode
    38,463
    Welcome to TFP!!!
    Please add your pool details to your signature as described HERE as it will help us help you.
    Jun 2015
    Lehigh Valley, PA
    7
    This happened twice to my brother in law. The first time the Easytouch system went into drain mode for some reason, and the 2nd time the valve actuator broke on the suction side and was stuck with the spa drain on and pool returns. Pool is about 2 years old.
    24,500 gal free form gunite, 3' - 8', Intellichlor IC40, Intelliflo VS pump, Sta-Rite S8M500 cartridge filter, Sta-Rite Max-E-Therm 400 heater, EasyTouch automation w/ Screenlogic interface, Aquabot Rapids 4wd cleaner. Taylor K2006 test kit.
