Thread: Leave cover with heat conservation
    Jun 2015
    Murfreesboro
    29
    I have a brand new pool with gas heater, just opened this week. What will be the best approach for leaf cover. Should I get a pool blanket (like a bubble rap available online) that will cover the pool to keep water warm and conserve gas heater bill. Can it be used as a leave guard during the fall or should I buy a separate pool cover for leaf.
    38,524
    Re: Leave cover with heat conservation
    Any cover is just going to collect leaves on it that you will have to scoop off.
    You can either get the "solar covers" that are the bubble type which will help lower the heat loss at night or something more permanently installed. Either way, they end up dumping the leaves in when you try to remove the cover.
    Jun 2015
    Murfreesboro
    29
    So what is your suggestion to avoid fall leaves while still using the pool before placing a permanent cover for winter. Can you still run the pool pump, automatic cleaner under permanent winter cover. Thanks
    38,524
    I defer to others ... since my solution is to not have trees or need to close in the winter
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If you don't plan on swimming any more for the season, just waiting for the water to cool to 60 before closing, then your best option is to put on the winter cover and keep running the pump, chlorinating, until you're ready to close. That will keep the leaves out of the pool and actually help the pool cool down faster if it's a cover that does not rest on the water, like a safety cover.
    We've gotten a few warmer days this weekend and into this week so I'm leaving mine open for now. Most likely next weekend, I'll be putting the safety cover on but still maintaining the pool until the water hits below 60 for closing.
    Isolated Spa - 345 Gallons
