Thread: Cracked Dome
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Cracked Dome
    I have a fine hairline crack in the dome for my in-floor cleaning system. The part costs $175.00. Is there a way that I can repair it? The crack is about 11/2" long and runs horizontal to the black sharpie mark.
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Cracked Dome
    There is a product called Plast-Aid that I use for hairline cracks, particularly in acrylic shells, that would probably do the trick. Sand and clean the crack from the inside first, then smear on a couple of light coats.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Re: Cracked Dome
    Thanks, can I buy this locally?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Cracked Dome
    SCP stocks it, so you might find it at a local store if you call around. I only know of one that carries it around here but I haven't looked any further.
