Thread: New Pool - Pre- SWG Installation Chemistry
    dmcody's Avatar
    Jun 2008
    Pittsburgh, PA
    71
    New pool opened this weekend. The SWG is not in yet, being completed W this coming week. Levels are:
    FC - 1
    pH - 7.2
    TA - 40
    CYA - 0
    Hard - 210
    I was going to add shock with Stabilizer to raise Cl and CYA, but not not sure about TA and pH. Should I balance everything now, or wait for SWG to be installed?
    Heres the new pool. Still active construction, but we are swimming!
    Pool Type/Size: Inground Vinyl ~24,000 gal ~ 18' x 36'
    Filter Type: Pentair FNS Plus 36 - DE Filter
    Pump: Pentair Challenger - 1.5 hp
    Heater: Pentair Mastertemp 250K BTU
    Accessories: Hayward AquaRite SWG Controller
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Re: New Pool - Pre- SWG Installation Chemistry
    I have two links for you. I hope these help.
    Pool School - Start-up New Plaster
    That is a pretty pool!
    Kim
    The person you should really be asking is the PB as he holds the warranty card! (I just thought of that-opps!)
    Do you have a good test kit yet? Look in my siggy to find the ones we use and love.
    Kim
    dmcody's Avatar
    Jun 2008
    Pittsburgh, PA
    71
    Thanks. I know the levels are low, just didn't know if i should adjust them before the SWG was installed. But I think you hit the nail on the head. Keep, Cl up and let the PB deal with it due to warranty issues. Thanks
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    you can add shock with stabilizer to bring up both FC an CYA, but be aware at the stabilizer in the shock is acidic and may probably drive your pH down. Of course depending on how much you add will be the determining factor. So dont be surprised if that happens and be ready to raise the pH back up to Low 7's if that happens.
    Quote Originally Posted by dmcody View Post
    FC - 1
    pH - 7.2
    TA - 40
    CYA - 0
    Hard - 210
    Divin Dave,
