Thread: Losing a lot of water, replace spider gasket?
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    I'm losing an inch of water a day it seems. I checked where the backwash water comes out and the pipe is full and slowly water is coming out while in filter mode. I have a Pentair sm10-3 multivalve (side mount) and my best guess is to replace the spider gasket. Does that sound right? Anything I should know beforehand? I watched a video of someone replacing a gasket and they put some sort of sealant on it - should I do that? If so what kind? Should I just close the pool (getting close to time anyway) and replace the gasket in the spring?
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    38,237
    Re: Losing a lot of water, replace spider gasket?
    Certainly sounds like the spider gasket is indeed leaking.
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    434
    Replaced the spider gasket yesterday and did not lose any water overnight. As an added bonus, the pump did not lose prime either!
    38,237
    Nice work! A leaking spider gasket can certainly be the cause of both of those.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Not a bad idea to pull and re-lube that spider gasket yearly either.
