Results 1 to 10 of 10
Thread: Pipe leak??
    Jun 2015
    Little Falls,NJ
    16
    Pipe leak??
    Hello all. Wanted to know if this is something I should be concerned with or something I can really seal myself.
    In-ground Clayton-Lambert Plaster built 1965?
    Capacity: 20,400 Filter: Sand
    Pump: Hayward Max-Flo II
    1 skimmer & 1 return - Floating chlorinator - TFT-100 Test Kit on the way...currently using Taylor pH, Chlorine and TA test and Pool store test.
    Jun 2014
    15,159
    Re: Pipe leak??
    My eyes must be playing tricks on me because I'm having a hard time spotting the exact leaky area. On the bottom pic, I do see a couple fresh drops on the skimmer basket, but can't pinpoint the origin of the leak. Can you help clarify?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pipe leak??
    To me it looks like the leak is coming from the pressure gauge in the top image. That should just be a matter of removing the gauge, removing the teflon tape, cleaning the threads then new teflon and reinstall the gauge. Just don't over tighten.
    Bottom pic, cannot tell what is leaking. See some water on top of the outlet fitting but is that coming all the way down from your multiport? or elsewhere?
    Isolated Spa - 345 Gallons
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pipe leak??
    Same here, but I would suggest installing a new quality gauge if you are going to go to the trouble of removing and replacing it, most of the standard pool company gauges are rather cheaply made to say the least. Check out the much better quality gauges at tftestkits.net they are only $11 plus shipping and WAY better than the stock gauges
    Jun 2015
    Little Falls,NJ
    16
    Re: Pipe leak??
    For the second photo I circled the area where there's always a small puddle around the pipe.
    May 2013
    Long Island NY
    419
    Re: Pipe leak??
    That is similar to my set up. Correct me if I'm wrong but the 2 piece that you have circled are glued PVC pipe and fitting.
    And your saying that it is leaking where the 2 are glued together. If that's the case, you may be able to take some PVC glue and spread it in the joint where the water is. It should drip in the crack and melt the two pieces together again.
    I had a PVC pipe leak at a fitting once and this worked. It's easy to try anyway.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Jun 2014
    15,159
    Re: Pipe leak??
    Ahhhh! In that case, it appears the PVC is going into a male adapter which then screws into the pressure side (top) of the pump. Perhaps the original glue failed a bit between the fitting and the pipe. I suppose you could try any number of epoxy resins to see if you could keep a seal on that spot. That may/may not work. You'd have to leave the pump off for a while so the epoxy could cure as well (pressure pushing out). Depending upon how much it's leaking, some might just leave it. Depends on if it's a severe leak or just s small nuisance dripping. In all cases though, the textbook, ideal method would be to simply get a new fitting, a small bit of PVC pipe, and just replace that portion. One thing you never want is for that pressure side pipe to come flying out of there and lose your water.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pipe leak??
    If the leak is where that arrow is someone did not put that glue joint together right, or more likely used the wrong kind of PVC glue, those black pump fittings are CPVC and the pipe is PVC so you have to use the special "universal" CPVC / PVC glue (usually comes in a red label can), not the more common PVC to PVC (blue, green, black, etc. label) or CPVC to CPVP type glues (orange label).
    May 2013
    Long Island NY
    419
    Re: Pipe leak??
    Quote Originally Posted by Isaac-1 View Post
    Nice catch! Brilliant ! The right glue is the key.
    Jun 2015
    Little Falls,NJ
    16
    Re: Pipe leak??
    You guys are awesome. Alrighty then! going to do this fix after I close my pool while the pump is off. Perfect!!
