Have a couple of problems and don't know where to start. Intex old style Plunger valves are stuck and leaking around connection. Also leak from Pro-Series modification connection on bottom. Looks like the leaks are from the hose connections on the intake side and pool wall on the out. I've tried tightening and using the lubricant from the pool store. Please Help!
Thank you,
Cgisharon
Quote Originally Posted by cgisharon View Post
Thank you,
Cgisharon
Forgot to add my pump also churns makes a lot of noise then shoots water out.
