Thread: Older Hayward H400 Pool Heater - need help findind blower motor
    Sep 2015
    Richardson tx
    2
    Hi all,
    I have about 15 year old Hayward H400ID1 with a defective blower motor assembly. I checked with Hayward and the part number I need is IHXBWR1930 which is list as NLA. That is for the entire assembly
    The motor itself is a Magnetek 208-240V 0.6A part# JE1F030NS and If I could find a substitute for that, I could probably replace the motor and reuse the housing. I can't find that motor listed anywhere.
    Anyone have any ideas?
    Thanks!
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Re: Older Hayward H400 Pool Heater - need help findind blower motor
    Yes that blower is usually NLA. Here are a few links from a quick Google search that might help you.
    hayward idxlbwr1930 | eBay
    Amazon.com : Hayward IDXLBWR1930 Combustion Blower for H-Series Low NOx Heater : Patio Heaters : Patio, Lawn Garden
    I would make sure everything else on that unit is is in good shape before putting any money into it. As you can see from your own search of the motor, many parts are obsolete.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Sep 2015
    Richardson tx
    2
    Thanks for the reply. I had someone come out and look at it - when they bypassed the motor it worked fine. I had replaced the control board a few years ago and it worked intermittently. I will never again use the pool company recommended by American Home Shield. They spent 6 or 8 hours trying to make it work and never once suggested it might be a blower motor problem.
    The other company diagnosed it in under an hour, but can't get the part.
