Thread: Confused
    Confused
    Hi
    Just thought I would ask here I am completed confused why I get green algae
    My levels are
    FC 6.5
    PH 7.8
    Alk 125
    Cal 400
    CYA 50
    I just poured 110 oz of chlorine in there to bring it up to shock level or slam .
    I just did this about 3 months ago .
    I dont understand why the algae comes back when my chlorine levels are around 6-7 ppm.
    I though I would check here to see if anyone has any ideas.
    Thanks
    Mark
    6000 gallon Viking fiber glass pool Blue Safire with 250gallon Spa spill over , (Frog chlorinator not hooked up ) , Jandy filter cartridge, Sta-Rite heater 333 Btu , Liquidator
    38,281
    Re: Confused
    Have you completely followed the SLAM process until you passed the three criteria to stop?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Confused
    Have you checked for hidden pockets of algae where there is poor water circulation, such as behind ladders or in light niches?
    Re: Confused
    I did follow the criteria a few months ago . I just started the process again
    a few hours ago.
    Quote Originally Posted by Isaac-1 View Post
    Well this pool is pretty small . I have no ladders . I did notice it on the steps around the corners. I brushed the whole pool and then put in the chlorine to slam it.
    I just wouldn't think it would have algae at 6.5 ppm . Unless I let the levels get low and it creeped up on me . It has been very hot here close to 100 for days
    30,419
    Re: Confused
    As a general observation based on doing this for around 10 years, this seems to be the most active time for algae to creep into pools. I am not sure why but we get more post like this in August and September than in the prime swim season of May June, July.
    If I had to say why, I think it might be that the water is warmest in August and warm water means a higher chlorine consumption than at other times. It also could be influenced by folks letting their guard down and allowing the FC to drop. It is probably a combination of many factors......some of which we don't fully understand.
    I think the best advice is to be especially vigilant as your swim season winds down. Extra chlorine and a little extra management will probably keep most pools crystal clear.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Re: Confused
    Quote Originally Posted by nomad26 View Post
    Hi Just thought I would ask here I am completed confused why I get green algae
    My levels are FC 6.5 PH 7.8 Alk 125 Cal 400 CYA 50 Mark
    Q: Are you using one of the recommend test kits for testing?
    Q: Are you getting green algae spots (here and there), or the whole pool has turned green, because walls and floors are covered with a film of algae?
    My best guess would be not brushing as necessary, and/or poor circulation in those areas if they are just spots. My friends, who lack returns in larger pools, usually have algae spots in August, when it is hottest. They usually slack off on the brushing part. Once they get back to brushing, algae seems not to show up ever again (if they maintain proper water chemistry). Please keep us posted!
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
