Thread: Snow on my cover!!!
    Sep 2015
    perkasie, pa
    1
    Snow on my cover!!!
    I switched to a mesh cover last year on my in ground pool. When I closed the pool I used four tractor tubes spread evenly under the cover...six or eight would have been better. The tubes were great until the snows began in December and never melted until March. The snow and ice got thicker and heavier, pulling the cover closer to the edge. The tubes held up ok. Any ideas as to how to remove the snow before it builds up? Or has anyone tried stacking the tubes by 2 or 3 to build a pyramid type structure? Thanks for any suggestions.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Snow on my cover!!!
    There's really no way to get it all off. You can try to stay ahead of it by using a pool brush to sweep it off every time it snows, but if you get 6 inches or more of sticky snow in one snow fall... good luck.
    Isolated Spa - 345 Gallons
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Up north we have a device called a roof rake. It would probably work okay for what you are trying to do.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by pabeader View Post
    I was thinking of that as a suggestion as well. Most of them have rounded corners and edges but be careful when using one of those so you don't damage the cover. They can damage shingles when used improperly so could damage a cover too.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    I've even seen them with little rollers on the edge for that!
