Did i read it was a new plaster pool, you mentioned curing. If your Langleir scale is corrosive it could be pulling the calcium out of the walls of your pool.
Hi Guys!
Thanks for the comments/suggestion. So I received my speed stir and retested my water. Since we had rain water and I added water to replace the one evaporated (I started to heat my pool to 90 degrees as it get cool). My CH reading are now 475PM. So not sure if the speed stir made the different or the rain and added it water....my gut feeling tell me a bit of both as I noticed my AK results are now lower than what I used to have. I will take all of your input keep my CSI in check and see what happens next year when I open my pool.
My conclusion is that the speed stir does have an effect on testing (and make it convenience to mix the chemicals without mess and too much efforts). Thanks for all your knowledge and comments to help with my issue.
I don't follow why you can't conclude definitively if it was the speedstir. Why don't you take the measurement with and without the speedster to see if there is a difference.
Read these -
FIVE SOURCES OF ERROR IN WATER TESTING...and what to do about them
TWO WAYS TO IMPROVE DROP-TEST ACCURACY
UNDERSTANDING CALCIUM HARDNESS
RECOGNIZING A COMPROMISED REAGENT
The CH test is one of the hardest (probably second in line to CYA) to perform as it can have a very ill-defined transition of red-purple-blue especially once your CH levels get higher than 500ppm. The drop count starts to go way up (even with the 10mL sample size) and it's easy to lose count of drops or to form undersized droplets. As well, without good lighting, it's hard to see the exact point at which the purple intermediate color transitions to blue. There is also the chance that the indicator dye is getting old and, unfortunately, no way to know for sure if it is bad. Finally, there are metal interferences with this test (Cu and Mg) that can sometimes cause the blue endpoint to not show up at all.
I have 750ppm CH in my pool. I measure CH every few weeks or so and I can easily get +/- 50-75ppm fluctuations. The test is not perfect. I also have a SpeedStir and, while I love it for all the other tests, I find that it doesn't help as much with the CH test because I need to use the 10mL sample size and the stir bar makes it hard to see the solution.
Don't get too worked up about CH. As long as your CSI is within -0.2 to +0.2, you have very little to fear from scaling or plaster etching. Also, being in NJ where you will be constantly draining and refilling your pool as well as battling with rain dilution, the CH fluctuations are the least important parameter to worry about. Keeping your CYA and FC in check will have more effect on overall pool water quality than CH.
