Results 1 to 10 of 10
Thread: First Test Results VS Pool Store
    EvanWilliams's Avatar
    Sep 2015
    Plano,Texas
    28
    Just getting started----pool looks great but.....
    Been at working until 8-9pm last few days.
    Wife was mistakenly adding Muriatic acid instead of chlorine liq.
    Pool Test Results:
    Robertson's Pools--Frisco--Automated Testing
    Sat Index 1.1.
    TDS 1400
    CYA 75
    Total Cl- 0.1
    Free Cl- 0.1
    Ph 8.1
    Total Alk- 148
    adj TA 128
    Total Hardness 529
    TFT 100 Kit
    Cl- Questionable pink? very slight if at all. I'm calling zero.
    Total Alk 180
    CYA 50-70 wife vs my vision
    Ph 7.8 (K 1000)
    TC by (K1000)===None
    ETA: Used pool math and will test later!!!!!!
    It's fun playing chem lab again.
    IG: 15000 Gal. Plaster. DE. 1992. Spa. Pump----(Will check brand and update). Heater. TF-100 Kit w Speedstir
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,254
    Re: First Test Results VS Pool Store
    Are you positive, your wife was adding MA and not chlorine? Your PH should be very low. With 15,000 gallons, every 10 oz. of MA will lower PH by about .2. A gallon would of sent the PH way below what you are testing. Forget the pool store testing and stick with yours as it will just complicate things.
    Please post a full set of results and please follow the instructions on the yellow card. If you have the speed stir, it should only take a few minutes:
    FC
    CC
    TC = FC + CC
    CH
    TA
    PH
    CYA
    Please check TC and CC with the drop based kit to start. This will tell if you will need to SLAM.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Sep 2015
    Plano,Texas
    28
    after chemical adjustment.
    K--1000 daily test
    Ph 7.5
    Cl- Positive
    Well, we can proceed!!!!!
    Free Chlorine----6
    Combined Chlorine----0
    Total Chlorine----6
    Calcium Hardness---500
    Total Alkalinity 200
    CYA--60
    Catanzaro's Avatar
    Jul 2014
    2,254
    Plug in your figures into pool match and check out your CSI. (Calcite Saturation Index)
    http://www.troublefreepool.com/calc.html
    I am not 100% on the CH as I believe Texas water is high in this area. TA seems a little high. Recommended levels are as follows:
    Do you keep a timeline of your levels? Are you having issue with PH rising and that is why Muriatic Acid has been added? Definitely recommend you perform an overnight test.
    Pool School - Perform the Overnight FC Loss Test (OCLT)
    Sep 2015
    Plano,Texas
    28
    CSI 0.6
    I''ll monitor Ph daily for awhile and see how it goes.
    I'll study up on overnight test.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Texas is a big place and has a LOT of variation on fill water, particularly on the topic of CH. While I am not in Texas, I am only about 20 miles away from Texas as the crow flies and my fill water CH is usually around 50 ppm depending on time of year, the lowest I have ever tested came out at 30 ppm.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Our water in Dallas is fairly hard and fairly high TA. My pool has been filled for a little over 3 years and the hardness started at 160 and is now 410. I have to actively lower TA following this process, Pool School - Lower Total Alkalinity
    Catanzaro's Avatar
    Jul 2014
    2,254
    Quote Originally Posted by EvanWilliams View Post
    CSI 0.6 I''ll monitor Ph daily for awhile and see how it goes. 'll study up on overnight test.
    Here is what Pool Math has, and I believe you are right there on the levels (borderline). Please play around with the figures and lower PH to determine if your CSI is lowered. There may be other ways to lower the CSI, but maybe someone who is out in that area can help you out. Luckily, in our area, our fill water has near perfect levels on PH, CH, TA. I made a mistake of adding well water in the beginning, but it was in such small amounts that there was no effect to the total picture.
    Calcite Saturation Index - requires pH, TA, CH, CYA, Temp, uses Borate, Salt Less than -0.6 is suggestive of problems for plaster, tile, stone, and pebble pools. Greater than 0.6 is suggestive of problems for all pools.
    Sep 2015
    Plano,Texas
    28
    PoolScreenshot.jpgGood morning.
    Thanks for info.
    Will be working on stuff slowly
    I intentionally waited for cool weather to be close so that any mistakes I make will be in a more forgiving climate.
    Jan 2014
    Buckeye AZ
    807
    After a year of liquid chlorine, I have enough salt in the pool (3500) that it mitigates the higher CH of my water, so I don't have to keep my pH in the low 7s to avoid scaling.
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
