Thread: Did CC guideline get lowered to < 0.5 instead of < 1.0?
    Sep 2010
    Orange County, CA
    52
    I see from the ABCs that if my CC is too high, it's time to SLAM. However, everyone here has usually told me if it's lower than 1.0, it's fine, but now I see it should be lower than 0.05. Did the guideline get lowered? I've sometimes had 1.0 and not worried about it. Today I have 1.5, so it's SLAM time
    Southern CA • 30K gal • Pebble • Pentair WhisperFlo 1HP 2 speed • Hayward DE6020 filter • Paramount Debris Canister • Goldline/Hayward AquaRite Pro SWG (T-CELL 15) Sense & Dispense (acid) • Pentair IntelliBrite 5G and GloBrite • Inter-Fab G-Force slide • Jandy deck jets • Lion head spout • Dolphin Premier Cleaner • Taylor K-2006 test kit
    Jun 2014
    15,059
    Re: Did CC guideline get lowered to < 0.5 instead of < 1.0?
    The <= .5 CC still applies, and is just one of the 3 criteria used to evaluate your water condition. An elevated CC simply means that your free chlorine is in the process of killing some organics, and those organics are in a "trash" state if you will, awaiting oxidation. When it goes over .5, we tends to look closely at all the readings and conditions of the water before jumping to conclusions. With your CC reading, you should also evaluate the clarity of your water, and if you still have a concern about algae, do an OLCT to confirm if you need to SLAM.
    When performing the OLCT, remember that it must be done when the sun has dropped – no sunlight on the pool. About 8 hours total is recommended. If you have an SWG, turn it off. Also, your FC level should be elevated more than normal. Starting (bedtime) FC could be close to your SLAM level, but no lower than 10. Anything less and you may not receive an accurate portrayal of FC loss (by percentage), even if it’s only 1 ppm.
    Jul 2015
    Western NC
    115
    Quote Originally Posted by Texas Splash View Post
    Shirley, you meant an OCLT.
    23,000 gallons IG gunite, pebble (I think)
    Hayward SP2610X15 1.5 HP Pump, Hayward sand filter
    Mineral Springs SWCG (it's actually Hayward/Goldline), Hayward Goldline T-CELL-15
    Polaris pool cleaner (with booster pump)
    TF-100, SpeedStir, K-1766 Taylor Salt Test, Lamotte Borate test strips
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Probably a bit of mis interpretation about this question.
    The CC has always been .5 or less (1 drop to go clear).
    The OCLT is 1ppm loss overnight or less
    Divin Dave,
