Results 1 to 10 of 10
Thread: Stabilizer sock
    Aug 2015
    Berryville/Virginia
    45
    Stabilizer sock
    I've seen posts referring to an organic stabilizer sock for the skimmer baskets. Where do I buy some? Thanks!
    ​aarsic
    30k gallon in-ground plaster pool, Pentair Whisper-Flo 2.0hp, Jandy AquaPure PLC 1400 Saltwater Cell, Polaris 360 w/booster pump, DE filter. Due to a brain injury I cannot do Pool Math. Don't tell me to do Pool math unless you want to walk me through the whole thing.
    38,305
    Re: Stabilizer sock
    Not sure why it must be organic ... should it be gluten free too?
    Most of use use any white cotton athletic sock. Or I use a t-shirt if I need to add a lot. It just needs to be something to hold the granules while they dissolve.
    Aug 2015
    Montreal, Quebec, Canada
    36
    Re: Stabilizer sock
    Kneehigh socks work well too,
    Just put it in the skimmer and let it dissolve. You can also hang it close to the return and let the water flow help it dissolve
    44000L oval above ground vinyl pool ---Taylor K-2006----
    Jacuzzi Saniclear 20 salt generator, Waterco XLRU50btu Heat Pump
    Jacuzzi L192 19" sand filter, Jacuzzi 1.5hp pump
    Pool School + Test Kits + PoolMath = Happy Times
    If in doubt SLAM - Shock Level And Maintain + Perform the Overnight FC Loss Test (OCLT)
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    Re: Stabilizer sock
    I used an unmatched sock that was my sons baseball sock lol
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Aug 2015
    Berryville/Virginia
    45
    Re: Stabilizer sock
    In 2007 Chem Geek (TFP Expert) wrote, "While some chemicals (notably Cal-Hypo) are incompatible with Trichlor that may be remaining in the inline chlorinator, that is not true for cyanuric acid or related cyanurate products. However, the sock material is organic so I'd make sure there's no Trichlor in the chlorinator when you put in the sock."
    Note - I did not bump that thread or any others pertaining to a sock but I wondered about the organic part.
    ​aarsic
    30,424
    Re: Stabilizer sock
    Any old sock will do just fine.
    Aug 2015
    Berryville/Virginia
    45
    Re: Stabilizer sock
    Thank you.
    ​aarsic
    38,305
    Re: Stabilizer sock
    I had never seen that discussion about putting it in a chlorinator. The flow rate is low, so in the skimmer is likely better.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Stabilizer sock
    That quote referred to an "inline chlorinator" not a floating dispenser. Inline chlorinators are plumbed in at the pump room so have strong flow rate when the pump is on. That quote is not relevant to this discussion since the OP isn't talking about putting Trichlor in a sock but rather CYA and that's OK to do. It's concentrated Trichlor that should not be combined with organic material. CYA is different since it does not contain chlorine.
    Aug 2015
    Berryville/Virginia
    45
    Re: Stabilizer sock
    Chem Geek is the best!
    ​aarsic
