Thread: Covering a large lazy El
    Sep 2015
    Boston, ma
    1
    Hi. We have a large lazy el that has always been covered by a safety cover. Unfortunately, we aren't able to get another winter out of it. Not wanting to spend 3-4 k for a new one, I'm looking to cover it with a regular winter cover. I have not seen any rectangular covers that would do the job, even with folding under some of the cover, as I have read here. Any suggestions? I am thinking about two covers...one for the deep end and one for the shallow, but I'm guessing that the point where they meet will allow everything to get into the pool, thereby defeating the purpose. Thought?
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    Re: Covering a large lazy El
    Hi Delcan, and welcome.
    Have you considered attempting to patch you existing winter cover, or even laying tarp on top of it? If the strapping and anchors are still good, you might be as well off that way.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    If you can lay a tarp over your existing cover, try that first as Swampwoman has suggested. If the cover is completely damaged, then try Pool Supplies - Swimming Pool Equipment and Spa Supplies by In The Swim. They may be able to produce a cover to match your old cover. Considering you can lay it out hopefully in the driveway, or the street, You can easily measure everything and then have them create one. I know other people have used them and they are very reasonable.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
