Thread: Solar cover question
    chopshop's Avatar
    Aug 2015
    Florence, AZ
    34
    If I use a solar cover at night will it affect the skimmer, or if I'm using the solar cover should I just use the main drain while the pump is on? Logic tells me to use the main drain only....
    11k gal., IG, Pebble, Hayward 425 Cartridge, Hayward Eco-star Variable speed pump, 3-5-4, Startup 9/1/15, In-floor cleaning system, City Water, Aerator, Full sun, and of course ambition!
    38,299
    Re: Solar cover question
    The skimmer will still pull in water, just not off the surface very well. I would not think there is a need to change the valves just based on whether the cover is on or off. In fact, with the cover on (if during the day), you may want to pull the warmer water off the surface with the skimmer so that the heat mixes.
