Thread: How to handle metals
    Sep 2015
    Little Rock AR
    12
    I use well water and with higher chlorine levels when I add water I can get a green tinge to the water.
    I added about 10% water yesterday and have the tinge this morning.
    in the past I used something from the pool store to remove.
    What is the TFP method for dealing with this?
    21x13x4 8,700 gl Splash Titan AG Vinyl
    Super Pak PL150
    Taylor 2004 Kit, waiting for DAP/FAS test kit
    Little Rock , AR
    Jun 2011
    Long Beach, CA
    2,781
    Re: How to handle metals
    Here is a write up in Pool School, Metals in the Water and Metal Stains.
