Thread: help to install on my catalina spa pump
    Sep 2015
    Saint-Calixte
    1
    Hi
    My 2 speed pump on my catalina spa has broken and i went to a reparator to check it and he confirms me that it is totally broken. So he gave me back my pump but in pieces. My problem is that i want to order a new pump on the net but to install it i have to know how to wired it correctly. Is it the red wire or the black wire that go on the high speed connector? I read on the internet that it depends of the company. Can somebody know how a catalina spa pump is wired? Or how i can check it? I live in canada for the electricity norm.
    Thank you very much
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: help to install on my catalina spa pump
    I found this manual, on page 40 it shows the wiring diagram.. you can also call them and they can talk you through wiring it back up..
