Results 1 to 16 of 16
Thread: Chlorine not holding ?
    Sep 2015
    Riverside , Ca
    5
    I have been working on this pool 28,000 gallon for about three weeks now, and can Not get a
    Chlorine reading of any kind ? I have added the proper amount of Conditioner the Ph is reading
    at 7.6 and the TA is at 100 what is going on. I have added 3 gallons of liquid chlorine and 4 Tabs
    just to try to get a reading and nothing . What is going on any help would be Great Thanks.
    Troubled
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Chlorine not holding ?
    Welcome to TFP!
    Three gallons of chlorine could be used up in an hour in a pool with algae. Check out SLAMing Your Pool and follow the process. You should see chlorine immediately.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    How are you testing? Do you have one of the recommended test kits? 3 gallons of what % strength liquid chlorine? Please post up a full set of results.
    In order for the TFP community to assist you in clearing up your pool, we need some information from your own test kit.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Sep 2015
    Riverside , Ca
    5
    I am using liquid chlorine full strength, I have brushed all the algae and cleaned the filters twice
    it is Staying algae free at the moment but getting cloudy at times ?
    Sep 2015
    Riverside , Ca
    5
    I am using liquid chlorine, not sure what the strength is, I am using a Taylor test kit.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    Something is consuming the chlorine, probably algae or ammonia. The solution is to keep adding more liquid chlorine or bleach and SLAM your pool following this process, Pool School - SLAM - Shock Level And Maintain
    Aug 2014
    Northern IL
    4,615
    What is the CYA level?
    SW Indiana
    9,199
    Quote Originally Posted by breal951 View Post
    Why it gets cloudy, it will use up more chlorine than you've added in just an hour. You should be testing every hour until most of the chlorine is still there from one hour to the next. Then you can start waiting a little longer between tests.
    Aug 2015
    Montreal, Quebec, Canada
    36
    Hi breal951,
    Would you mind posting your full tests results?
    It is possible that you have algae growing even if you don't see the bloom accumulation yet.
    You might need to slam the pool, but knowing your full results, especially CYA, we can guide you better.
    Also, what is your primary method of chlorination, I see that you are using liquid chlorine and tabs as well. What Tabs are you using?
    44000L oval above ground vinyl pool ---Taylor K-2006----
    Jacuzzi Saniclear 20 salt generator, Waterco XLRU50btu Heat Pump
    Jacuzzi L192 19" sand filter, Jacuzzi 1.5hp pump
    Pool School + Test Kits + PoolMath = Happy Times
    If in doubt SLAM - Shock Level And Maintain + Perform the Overnight FC Loss Test (OCLT)
    Sep 2015
    Riverside , Ca
    5
    The Ph is 7.6 the TA is 100 and the CYA is 100 as I added conditioner about three weeks ago and the pool is
    28,000 gallons, Thanks
    Aug 2015
    36
    On my test kit, 100 cya is the maximum range, ( what test kit do you use)?
    Sadly your CYA might be higher than that. With such a High CYA, it may be impractical to SLAM. With that high of CYA and the cloudiness, you are not getting enough sanitation to kill the algae.
    You can retry the test but with 1:1 pool water and tap water, multiplying the result by 2.
    If the CYA is still over 100, you might have to drain some of the pool water to get the CYA to a level that we can manage and then SLAM to kill the algae.
    The tabs you are using increase the CYA. Maybe removing them completely and switching to bleach may be your best bet.
    Sep 2013
    Connecticut
    728
    Why did you add conditioner (CYA presumably) recently? Did someone advise doing so?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Sep 2015
    Riverside , Ca
    5
    I checked the conditioner and it was only reading around 40 so I added 5 pounds.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    What are you using to test? How long after adding are you testing?
    Sep 2013
    Connecticut
    728
    5 lbs. in 28,000 gallons shouldn't have raised CYA from 40 to 100+.
    How are you measuring CYA levels (and other test results)?
    Unless you are using a salt water generator for chlorination (are you?), CYA at 40 would have been pretty good...
    Aug 2014
    Northern IL
    4,615
    Yes. You said you had a Taylor kit. Which model?
