Results 1 to 20 of 20
Thread: Got my TF-100 Test Kit with first results
    Jun 2015
    Little Falls,NJ
    16
    It has rained a couple of days and walked outside and there was algae growth at the pool floor. I brushed the pool and turned the filter on and anticipated the arrival of my TF-100 kit.
    I purchased a home with a pool and up till now, I've been using basic Taylor pH, Chlorine and TA test.
    So I tested my water with the TF-100 Kit and here's my results:
    pH-7.8
    FC-20
    TC- >5
    CC-2
    TA-130
    CH-400
    CYA-75
    Any recommendations on what to do?
    Currently after brushing the pool,the water is still cloudy. I would like to get appropriate levels before I close my pool for the winter.
    Going to SLAM the pool so I added the appropriate amount of Bleach as suggested by the Pool Math to get the FC levels to SLAM levels as per CYA levels.
    Thanks guys in advance!
    In-ground Clayton-Lambert Plaster built 1965?
    Capacity: 20,400 Filter: Sand
    Pump: Hayward Max-Flo II
    1 skimmer & 1 return - Floating chlorinator - TFT-100 Test Kit on the way...currently using Taylor pH, Chlorine and TA test and Pool store test.
    Jul 2014
    Hope Mills, NC
    567
    Re: Got my TF-100 Test Kit with first results
    I suggest you do it again. TC should equal FC plus CC.
    Also, you need the CYA number in order to know anything else.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Jun 2014
    15,189
    Yes, most definitely test your CYA. It's one of your most important tests. Proper lighting is important for the CYA test. You want to test for CYA outside on a sunny day, but keep the skinny view tube in the shade. Taylor recommends standing in the sun with your back to the sun and the view tube in the shade of your body. Use the mixing bottle to combine/mix the required amounts of pool water and R-0013 reagent, let sit for 30 seconds, then mix again. Then, while holding the skinny tube with the black dot at waist level, begin squirting the mixed solution into the skinny tube. Watch the black dot until it completely disappears. Once it disappears, record the CYA reading. After the first test, you can pour the mixed solution from the skinny view tube back to the mixing bottle, shake, and do the same test a second, third, or fourth time to instill consistency in your technique, become more comfortable with the testing, and validate the CYA reading.
    Once you have your CYA, go to the Pool School - Chlorine / CYA Chart and find your corresponding FC for that CYA level. Since you have algae, you need to find your SLAM/Shock FC level and keep it there until you pass the 3 SLAM criteria. Read the Pool School - SLAM - Shock Level And Maintain page and follow the instructions carefully. It will work. Good luck!
    I should highlight that before starting a SLAM, one of the first things you must do is adjust pH to about 7.2. Make sure you do that first!
    Jun 2015
    Little Falls,NJ
    16
    edited with CYA level
    Jun 2014
    15,189
    Okay, you have a pretty high CYA. 75 is rounded up to 80. For a non-SWG pool, your target (normal day) FC should be 9, the SLAM/Shock level a 31. That's up there. Would you be willing to do a partial drain to exchange new water to lower the CYA some? Try to get the CYA down to about 50? If not, then you'll need enough bleach to get up to 31 and stay there until you pass a SLAM. If you have tabs in that floater, please remove them now. They increase CYA quickly.
    Jun 2015
    Little Falls,NJ
    16
    I stopped using the floater once I found out the have CYA.
    I can't do a partial drain at the moment. I added 242oz of 8.25% Bleach to get it to SLAM levels.
    Would partially draining the water when I close the pool be okay?I planned to do it then to help lower the CYA level.
    30,426
    Now, are you testing and keeping it at SLAM?
    Jun 2015
    Little Falls,NJ
    16
    I rechecked, my FC level so far. It is currently 38 for a CYA of 80. Recommended FC is 31 according to CYA/FC chart. My current pH is 7.5. I'm going to do the OCLT in the am.
    Aug 2014
    Northern IL
    4,615
    Let us know your results as soon as you get them. TFP protocol is that you can't test pH at FC levels over 10ppm. Just test your FC/CC for now.
    Jun 2015
    Little Falls,NJ
    16
    Okay just rechecked my FC and CC levels this morning
    Last night This morning
    FC-38 FC-39??
    CC-0.5 CC-1
    Jun 2014
    15,189
    I would recommend continuing your SLAM. SLAMs almost never complete in one or two days. Especially when there is visible algae in the pool. So be patient and have some more bleach ready to keep the FC at 31 all day. Why did it go up? It could've simply been something "slightly" off during the test from one test to the other. But there's no need to keep it much higher than 31. Too much and you'll just be wasting bleach and money. Your slightly elevated CC means the bleach is killing something and it's beginning to process for oxidation. So hang in there. "Maintain" that SLAM FC of 31.
    About your question earlier - after you pass the SLAM, and your water is A-Okay, if you chose to drain then to lower your CYA you can. I would probably just leave it until spring though. You don't have much more of a season right? SO when you close and re-open, you might find that the CYA dropped a little over the winter.
    Also, please go back to the SLAM page to ensure you are still doing all of the things each day it tells you to do. Those are very important for best results.
    Jun 2015
    Little Falls,NJ
    16
    Thank you very much. How often should I check the FC throughout the day?
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    576
    When I first did it, I was checking hourly until it held some then every two hours and so forth....
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Jun 2015
    Little Falls,NJ
    16
    Checked it 3 hours later and its still 39. Should it be going down?
    Jun 2014
    15,189
    If you are not adding FC and do not have any method of automatic chlorination, then yes, it should eventually go down. If it's cloudy today that might slow it down a bit.
    Jun 2015
    Little Falls,NJ
    16
    Yep pretty cloudy up here in North Jersey at the moment. Possible showers as well. Just did a re-check for the 3rd time today..
    FC-38.5
    CC-0-0.5(it looked clear after the R-0003 but put one drop of R-871 anyway)
    Unfortunately I work tonight and can't do anymore test.
    If it rains tonight, what can I expect when I do the test tomorrow morning when I get home?
    Jun 2014
    15,189
    Rain should have minimal effect on your FC testing. Contrary to popular belief, an occasional rain storm really doesn't skew our testing all that much. Have a good evening. We'll check numbers tomorrow.
    Jun 2015
    Little Falls,NJ
    16
    Ok rechecked FC when I got home.
    FC-34
    CC-0
    pH-7.8
    Water is a little clearer. Pump has been running since I started the SLAM. Psi still 10.
    I'm going to brush and vacuum. SHould I add Muriatic Acid and more Bleach?
    Jun 2014
    15,189
    Definitely no acid. Don't bother testing pH anymore while your FC is over 10. The high FC messes up the pH tests. Just focus on the FC for now and maintain your SLAM FC level. You're doing well. Keep-up the great work.
  20. Back To Top    #20
    30,426
    Great advice from Texas Splash. That pool is VERY close to becoming crystal clear. Run that pump 24/7 and brush and backwash as needed.......you are close.
