Thread: Water temperature difference between heat pump and prologic
    Apr 2012
    Newton, NC
    173
    We have had our pool since October 2012. Up until this year there has been a small (1-2 degrees) difference between the water temperature reported by the AquaCal heat pump vs. the water temperature reported by the ProLogic. The water temperature sensor for the ProLogic is in the pipe just before it goes into the heat pump.
    This summer the temperature difference between the heat pump and ProLogic is running 5-6 degrees. Is there a way to recalibrate the temperature sensor on the heat pump or the ProLogic? I have looked through the manuals and not been able to find any way to do it.
    I guess the other "solution" would be to replace the temperature sensor(s). Do they develop inaccuracy over time? It would be quite easy to replace the sensor that feeds the ProLogic. I suspect it would be much more difficult to replace the sensor in the heat pump (although I haven't taken off the front panel to have a look).
    Since I don't know of a way to get the water temperature inside the pipe, I don't know what the true temperature is in order to determine which sensor is inaccurate.
    Anyone else had this problem? If so, what was your solution?
    Thanks.
    Vince L
    16' x 37' fiberglass pool, 8' fiberglass spa, Hayward Swimclear C3030 filter, Hayward EcoStar VS pump, Goldline Pro Logic PL-PS-8, Goldline SWCG, Goldline Sense & Dispense pH control, Fiberstars LED's in pool & spa, AquaCal SQ175R heat pump, SR Smith Typhoon slide, Polaris 9300xi robotic cleaner, TF-100 Test Kit
    Ft Lauderdale, Florida
    1,455
    Re: Water temperature difference between heat pump and prologic
    Go to page 47, Water Sensor Calibration
    http://aquacal.com/webimage/pdf/aqua...ump-manual.pdf
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Yes, they can go bad over time, but often they go bad suddenly and drasticly
