Thread: How concerned should I be
    Aug 2015
    Arlington/TX
    20
    I was enjoying my Friday off after doing some lawn work this morning. I was enjoying a shiner in the pool, watching my Polaris clean the place up when suddenly:
    It looks like the threaded pipe on the backside of the jet. Do I now have another water leak? The pool has been holding water nicely since I had a leak guy come out, but the pump still loses prime on what seems like every third night.
    If I do need to change the jet, are they simply screw off? Or will it likely be more involved?
    My pool: In ground FiberTech coated; ~17,500 Gal w/ Pentair, 1.5-hp pump; Polaris PB4-60 turbo pump; Nautilus NS DE filter
    rdshackleford's Avatar
    Jul 2015
    Coatesville, PA
    116
    Re: How concerned should I be
    How many return jets do you have?
    29,085.1 gal inground grecian vinyl, Hayward Super Pump VS, Hayward S-240 sand filter, Dolphin Nautilus Plus (aka Agador Spartacus), Taylor K-2006 kit, nice pool brush, crappy leaf net, frogs
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The jet should just screw off of the fitting. I would take it off, get the piece out and try to determine where it came from. The color of the plastic looks like it came from a plastic part around the pumping station (almond color).
    Also... pass me a Shiner. I could use one today...
    Isolated Spa - 345 Gallons
    Aug 2015
    Arlington/TX
    20
    Quote Originally Posted by rdshackleford View Post
    Four jets. They pump pretty hard.
    Quote Originally Posted by JVTrain View Post
    Define pumping station. Are we talking something up near the filter?
    30,419
    Near the vicinity of the pump.
    Howewver, I think you will find it is the threads broken off directly behind the return eyeball....take it iff and see.
