Thread: Quality Vacuum Head
    Dec 2009
    San Antonio, Texas
    78
    Quality Vacuum Head
    I need a quality head for manual cleaning the pool. I used to have a good one; it was heavy and maybe made of zinc, but I tossed it out in the Great Mustard Algae Cleansing of 2014 - everything went, hoses, brushes, float, toys, and our vacuum head.
    I replaced the vacuum head at Leslie's - at $60 it was their most expensive, at least her, locally. Well, I went out today to vacuum the pool and it was dead. A wheel had strewn its bearings all over, the springs and bolts were so rusted that I wouldn't put them in the pool even if everything else worked, and the part of the head that connects to the pole was deeply corroded - maybe an eighth-inch thick. The head lived where it shouldn't - in close proximity to the tub of trichlor - and I'll store its successor elsewhere, but now I need its successor.
    So, where do I get a quality, heavy-duty manual pool cleaner/vacuum head?
    Thanks.
    Jaywalker
    In-ground, 11,000 gallon, plaster, in-line trichlor pucks or BBB bottled chlorine, 1.5 HP pump @ ~100 gallons/minute, cartridge filter
    Jun 2014
    15,292
    Re: Quality Vacuum Head
    If you're looking to shop primarily locally here in SA, and don't like the options at Leslie's, there are a few places on Hwy 281 between Bitters and Thousand Oaks:
    - Gary's Pools & Patio
    - Keith Zars Pools
    - Poolside Sales & Service
    - I also thought there was a Texas Pools in that area as well.
    - Closer to Loop 1604 & 281 you may find a "Warehouse Pool Supply" in the same shopping center on the corner as a Leslie's.
    I'm sure there are other stores locally. I just happen to go by there often. Other than that ... on-line.
    Dec 2009
    San Antonio, Texas
    78
    Quote Originally Posted by Texas Splash View Post
    - Keith Zars Pools
    Thanks. I'd better go there and see - my search terms are inadequate and I can't find anything online that I like.
    I thought Leslie's bought Warehouse. The one I used to go to down at 151 and 410 certainly changed.
    Jaywalker
    Jul 2015
    Tempe, AZ
    194
    http://www.amazon.com/Flexible-Swimm...2339978&sr=1-3
    I bought this one to supplement my aging automatic pool cleaner and it's been working well. But I don't have much to compare to. Unfortunately my aging pool cleaner has moved into the inoperable category and this vacuum head has moved from supplemental to primary.
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
