Results 1 to 10 of 10
Thread: i want to get Plastered (at least my pool table.)
    Sep 2015
    henderson, nv
    2
    Hello, just finishing my pool. plastering was 7 days ago. I have a pool table. I recently discovered that the bottom surface of the table (concrete) was not plastered. it is uneven and pitted. I spoke to my PB and he said he builds them all this way and there is no problem with it. He said you can't see the bottom so there is no cosmetic issue.
    I am concerned that the pool table will deteriorate with time as the concrete is not sealed and I have a salt pool. The bottom surface will be in water. Can concrete leach elements into the water? How do we correct this other than to partially drain the pool, but I have new plaster, how long before this can be done, and not damage the new plaster?
    Any thoughts would be appreciated.
    IN GROUND GUNITE/PLASTER 16,000 GALLONS JANDY EQUIPMENT WITH SALT GENERATOR AND JANDY 2.5 PUMP VARIABLE SPEED.
    Casey's Avatar
    SW PA
    10,457
    Re: i want to get Plastered (at least my pool table.)
    Welcome to TFP. I can't specifically answer your question but someone will be along shortly. It's still pretty early.
    We'd love to see any pictures you could share of your new pool. Again, welcome to TFP.
    Jan 2015
    las vegas
    92
    Plastering the bottom of the table is not necessary buy some type of sealer/waterproofer should be applied to the bottom.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    All that said, it could be an easy DIY to plaster it, especially since appearance doesn't matter. Put a tarp on the water surface to collect your spillage if attempting it.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    amandahein3's Avatar
    Mar 2015
    rowlett, tx
    853
    We also have a table but it's not concrete. We did travertine and sealed it. It's not plastered either.
    Free form pool 90'3" prim, 14180 gallons. TF100 Kit In pool table with travertine top, 3sheer descents, Depth 3.5-5-4, Jandy 2HP pump, Inline Chlorinator, Wetedge Satin Matrix Antigua.
    Jun 2014
    Roseville, CA
    343
    I would ask him how much he would charge to plaster it and have him do it.
    SWG: CircuPool (5/2018) Universal 40; 3000ppm seems ideal;
    My Ideal Specs:
    FC 5; PH 7.4-7.6; TA 90; CH 350; CYA 75; = SI ~ 0.19
    14,000 gal, in ground, plaster, Cartridge filter, Borates
    TAYLOR K - 2006 Last Circupool SI30+ 4 years RIP.
    Sep 2015
    henderson, nv
    2
    Quote Originally Posted by bob2015 View Post
    Okay, submitted this in 2015, now the bottom of the table has rust stains I assume from the Rebar that is wet from absorbing water thru porous concrete. Does anyone still think that I don't need to have it plastered????
    Aug 2014
    Houston tx
    2,525
    Won't the stains just leach out onto the plaster?
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Feb 2016
    Atlanta, GA
    145
    I always wondered why pool builders don't use epoxy coated rebar to prevent rust stains.
    Apr 2016
    Houston, TX
    208
    i just finished my build and our table does have plaster underneath...
    2016 pool build.... 18k gal. freeform style, built in round table, 18" jumping platform, travertine coping upgrade, travertine waterline, peagravel decking, saltwater pool (no spa), Quartzscape blue., 1.5hp Pentair pump, JANDY SWG, 48sqft Pentair DE filter, TFP-100 kit w/speedstir MYPoolBuild
