My brand new pool was filled with water in July 2015 and soon after, we discovered a pool leak. Pool was losing 3/4 inch to 1 inch of water per day. PB put epoxy in the back of the light niche and said that the leak was from the light conduit. Pool stopped losing water. I questioned PB as to why they didn't dig up the conduit and replace with new PVC conduit instead of patching with epoxy. PB said that even if they replaced with new PVC conduit, the conduit will likely crack again from settling issues.
What is the better long-term solution is for repairing a leak from the light conduit? Is the epoxy the best choice or should I have the PB remove the concrete that overlies the conduit, dig up the conduit, and replace the PVC conduit?
Is it likely that the conduit was damaged during back fill/concrete pouring or are conduit problems always related to settling of the ground? We have clay-soil (not sure if this makes a difference). How likely is it that the PVC conduit will crack again if it is replaced? How long does the epoxy last?
Any advice is greatly appreciated!
