Thread: Add more salt?
    Jul 2015
    Ceres Ca
    18
    Add more salt?
    Split by moderator from HERE. jblizzle
    I had my pool built in June of 2015 and added 7 50 pound bags currently my salt readings is 2850 should I put more salt in there
    live in central valley pebble Tech 18920 gallons pentair pump sheer decent salt water IGP built June 2015
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Pentair Salt water chlorine generator question.
    It is best to start your own new thread when you have a question.
    I would add more up to 3200 ppm since that is what Pentair says is ideal. But, it isn't a priority if the SWG is working fine, making chlorine and not giving a low salt warning light. Definitely, grab a bag or two next time you are at the store.
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: Add more salt?
    I like to do my own salt test and not rely on my SWG reading because while the device doesn't read salt level correctly, it works just fine. In doing my own tests I am assured of the level and don't over or under dose by mistake.
    Taylor's K-1766 Salt test kit is my test of choice.
    Jul 2015
    Virginia Beach/VA
    3
    Re: Add more salt?
    Definitely do not rely on the salt test tabs. I found the SaltDip Digital Pool Water Chemistry Tester SaltDip Digital Pool Water Chemistry Tester
    Sold by: In The Swim Pool Supplies on Amazon and it works great!
    Jim & Leslie Pasch
    Intex Ultraframe 18'x9'x52" AG (6900 gal)
    Sand filter Pump & SWG (Intex Model ECO 15110)
    Install date: 11 July 2015
    38,371
    Re: Add more salt?
    Quote Originally Posted by Jimp100 View Post
    We are generally not fans of digital tests. They require frequent and accurate calibration to keep them reporting numbers close to reality ... and even then there is no way to be sure it is not spitting out a random number.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Add more salt?
    Generally what is important isn't to carefully measure and maintain a specific salt level. The goal is just to keep the SWG system happy and generating chlorine. Sometimes as the cell is at the very end of its life I can get a false low salt reading, but other than that I just go by the control panels reading. Salt tests aren't very accurate anyway, so what's the point.
    chiefwej
