Thread: Quick question about salt pools,
    steve57765's Avatar
    Aug 2015
    Lexington NC
    47
    Does water splashed out of pools create salt lines on pools decks as water dries?
    wouldent salt corrode concrete decks, steel furniture on the deck?
    Ive been lurking these forums and learning a lot!
    Steve- 19K IG PebbleTec (sandy beach color pebble) final plaster/pebble August 2015
    Jandy pro cartridge filter
    Jandy pro series Plus HP PHPF pump w/waterfall
    Polaris 360 pressure cleaner- TF-100 w/SpeedStir
    50ppm Borates
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Quick question about salt pools,
    The salt level in a "salt pool" is very low. It's about the same as human tears. By comparison ocean water has over 10 times the salt. I never see any salt lines on the deck. Salt in any quantities can damage soft stone and cause corrosion in iron and carbon steel. But concrete and painted surfaces are safe.
    chiefwej
    Jul 2015
    Virginia Beach/VA
    3
    Agree. Not an issue at these low salt levels.
    Jim & Leslie Pasch
    Intex Ultraframe 18'x9'x52" AG (6900 gal)
    Sand filter Pump & SWG (Intex Model ECO 15110)
    Install date: 11 July 2015
