Thread: liner came off
    Apr 2010
    Central NJ
    227
    liner came off
    I had a liner which was installed this past June and this weekend I noticed that on one of the corners the liner came off. I also noticed that this is the only corner that doesn't have "clips" (sorry, don't know what else to call them), the other three corners have them. I have attached pic with and without clips. What are these things, and are they the reason why the liner came off? Should I ask the my pool vendor to place them on this remaining corner
    Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,444
    Re: liner came off
    Yea The other 3 with clips stay up. the one without is loose..............needs clips.
    Kim
    Apr 2010
    Central NJ
    227
    Re: liner came off
    Can you provide a link? I did a search and I only found clips for above ground pools and they don't look like what I have.
    thanks
    Jul 2012
    Tallahassee, FL
    30,444
    Re: liner came off
    I have NO idea how to find them. I have an above ground pool using liner lock.
    I have looked at your "clips" a few time and to me they look more like an afterthought or something like that. They look like they are just pieces of white plastic that was wedged in there. I wonder if the installer was having a hard time keeping the liner in place in the 3 areas so added these to keep it in place. For some reason this last corner stayed in for him so ............no clips.
    Of course NOW it is a problem. I think your best bet will be to call the installer and ask them about it.
    Good luck! Let us know what you find out so we can know if this happens in the future.
    Kim
