Thread: a friend is about to close pool for season. is it worth SLAMing or wait for spring ?
    lindaspoolboy's Avatar
    north NJ
    23
    A friend will be closing her pool soon (we're up in NJ).
    Sounds like she has been battling algae with help (i.e. harm) from local pool store.
    Is it worth getting under control now; or will the cold NJ winter kill off the algae so
    we can worry about getting her BBBed in the spring ?
    Thanks !
    - len
    29,000 gallon vinyl IG, Hayward 1.5hp Pump, DE Filter.
    30,421
    Re: a friend is about to close pool for season. is it worth SLAMing or wait for sprin
    Hard decision. If you close with a mess, you will open to a mess. Sorta' like the guy that says, " you can pay me now, or pay me later".
    Donldson's Avatar
    NW Ohio
    2,896
    If she SLAMs now, she opens to a clear pool ready to get going.
    If she closes as-is most of the algae will die in the cold NJ weather, but it isn't going anywhere. So the pool will be full of dead algae, live algae that will begin regrowing as soon as the cover is removed, and with no chlorine in the water she runs the risk of a CYA-ammonia conversion. If the CYA is converted then she will need a tanker of chlorine to remove the ammonia before the pool will hold FC.
    So it might not be more work to wait, but it certainly won't be less.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,774
    +1 ^ By attrition I had to open a foreclosed pool when I bought this house. If she has algae now, there is a very high chance she will open to black water with ammonia!
    As such, I'm reasonably confident its more a case of "pay now, or pay MORE later"
    Put that puppy away clean if you can
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jun 2014
    Oslo
    120
    If he is willing to accept some help, I think that you can measure the CYA for him. If the pool water has a big CYA concentration, than is better to clean the pool in spring time since the pool has to be drained anyway. If CYA is manageable, than one should consider SLAMing now.
    Just my humble opinion.
    South of France inground rectangular 17k pool - ruber membrane. Sliding dome, black thermal blanket covering 75% of the pool surface. Aqualux 3/4Hp pump, glass media sand filter, Zodillac robot, 110W UV-c lamp, Hayward brominator, Caliente 12kW heat pump.
    north NJ
    23
    Well, not what i wanted to hear; but that's why I asked.
    Thanks everyone.
