Page 1 of 3 123 LastLast
Results 1 to 20 of 53
Thread: A Few New Questions!!
    hellstorm2004's Avatar
    Jul 2015
    Richardson, Texas
    182
    Hello Everyone,
    I have a few questions. First here is a pic.
    1. Can you please tell me what the three levers are for?
    2. Is it ok to leave the pool robot in the pool at all times?
    Purex Titron FNS DE Filter 25000 gallons approx.
    Century A.O. Smith B855 56Y 2HP Motor. 40x25 (approx). Plaster surface.
    TFT-100 Test Kit.
    Rainbow Lifeguard 320.
    DX5+S Cleaner.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: A Few New Questions!!
    Valves to adjust the water coming from the pool. i would guess 2 and 3 would be for skimmers and 1 would be bottom drain vs skimmers
    but we really need more info about your pool to know for sure...
    I will have to let others that have robots answer that part.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Is it a robot (plugged into electric outlet) or a pool vac/cleaner with a hose going into the pool wall? Looks like you have a booster pump to run a pressure side pool cleaner. It is ok to leave a pool cleaner in the pool all the time. Generally, I have heard that it is better not to leave robots in the pool all the time.
    I agree with Bob on the valves, unless you have a suction cleaner then 3 would be for that.
    Jul 2015
    Richardson, Texas
    182
    What information do you need? I will let you know, provided i know!
    TFT-100 Test Kit.
    DX5+S Cleaner.
    Jul 2015
    Richardson, Texas
    182
    My main question is what happens if i turn these levers clockwise or anti-clockwise!
    TFT-100 Test Kit.
    DX5+S Cleaner.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Valves 2 and 3 adjust flow from skimmers and 1 decides between skimmer and bottom drain
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Handle inline full flow. Handle cross wise no flow.
    Jul 2015
    Richardson, Texas
    182
    By cross wise, you mean parallel to the ground?
    TFT-100 Test Kit.
    DX5+S Cleaner.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    You got it!
    Jul 2015
    Richardson, Texas
    182
    Thanks!
    TFT-100 Test Kit.
    DX5+S Cleaner.
    Jul 2015
    Richardson, Texas
    182
    Just one last question... is 10psi pressure too low?
    TFT-100 Test Kit.
    DX5+S Cleaner.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    10 psi is fairly normal. I'd say most set ups tend to be between 8 and 20 psi. 10 psi is your "clean" pressure after you've thoroughly backwashed and rinsed?
    Isolated Spa - 345 Gallons
    Jul 2015
    Richardson, Texas
    182
    I was thinking of recharging my DE soon. The thing is my pool is going through the SLAM process. So was thinking more pressure means quicker results!
    If you say 10 is fine, i guess i will be patient!
    TFT-100 Test Kit.
    DX5+S Cleaner.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    You should backwash after 25% increase over clean pressure.
    umpalumpajay's Avatar
    Dec 2014
    West Hills, CA
    157
    you have an attached spa? one of my valves i manually throw adjusts water flow either from the main drain to the spa (more overflow water into pool) or into the pool.
    12000g pool + 1000g spa. Jandy 2.0hp epump + separate Jandy pump for Sheer Descent. Jandy CV Cartridge Filter. Jandy Lxi gas heater. Tropical Breeze PebbleTec. Aqualink. Aquapure SWG. Nature 2. The Pool Cleaner 2x. Taylor K-2005.
    Jul 2015
    Richardson, Texas
    182
    Nope.. no spa!I plan to build one someday.
    TFT-100 Test Kit.
    DX5+S Cleaner.
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Quote Originally Posted by pabeader View Post
    Not true of pool valves. If you look across from the handle you should see an area defined and the word "off" printed. That corresponds to the gate inside the valve. So where ever you set the off area will close off that area of the valve. The handle being across the direction of flow should actually be fully open on a two port valve. On a three port you have to look at the markings and the relative position to the ports.
    chiefwej
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by chiefwej View Post
    ABSOLUTELY!
    There are pool valves (typically ball valves) that behave like pabeader stated however these are not them.
    When the OFF indicator of the handle is facing a pipe connection, that pipe is shut off from flow. When the the OFF indicator is facing away from all pipe connections all pipes are open to flow (like #2).
    When the handle is at an angle like #1 and #3, the pipe connection that the OFF marking is partially covering is.....partially closed.
    So in your case:
    Valve #1 - When long grip part of handle faces pump, water flows from the pump to both left bound and right bound pipes.
    - When long grip part of handle faces right, water flows from the pump to [right] bound pipe.
    - When long grip part of handle faces left, water flows from the pump to [left] bound pipe.
    Valve #2 - When long grip part of handle is horizontal (cross pipe), the valve is fully open and water flows from top to bottom. To close that valve, rotate handle to be vertical (in-line with pipe)
    Valve #3 - Same as Valve #2
    Last edited by gtemkin; 09-11-2015 at 10:50 PM. Reason: Mistake in Valve #1 second and third cases [fixes]
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    My bad! I was unable to zoom in enough to actually 'see' what I was talking about. I defer to those who know more than me about this.
  20. Back To Top    #20
    Jul 2015
    Richardson, Texas
    182
    Thanks for the detailed explanation.
    Can you check this pic. Its a little dark, coz took it just now. Does it mean that its taking full input for skimmer and main drain?
    TFT-100 Test Kit.
    DX5+S Cleaner.
