Page 1 of 3 123 LastLast
Results 1 to 20 of 51
Thread: New Pool: Klein, TX (no spa)
    This will be my second pool:
    First pool was:
    Chlorine (bleach eventually)
    Pebbletec
    Three, single speed pumps (filter, cleaner, bubblers&water wall)
    PCC2000 in-floor cleaner
    Cartridge
    Pool builder (same as first pool) recommends UV/Ozone as the sanitizer. My 1st pool had Ozonator, I'm not sure it did anything. What can you TFP folks tell me about UV as a primary sanitizer?
    Here are my plans:
    Variable Speed pump -> Intellipro. I want to run low and slow to save those $$s
    Filter options (DE or Cartridge Filter), I'm leaning towards DE, but my wife is concerned about the carcinogenic properties of the DE medium
    in-floor cleaner (I loved my in-floor cleaner)
    Color changing lights
    This will be some form of Pebbletec - I want more blue and less green to the finish
    Chlorine tank and pump (peristaltic, Stenner 45MPHP22, w/7.5 gal uv gray tank and rain roof) Single Head Fixed Chemical Injection Pump
    - cabinetry and counter space
    - gas plumbing (Grill/Generator/firepit)
    - wiring (lights, fans, speakers, TV)
    - water/sink/drain?
    - cooling sprays aerators (integrated method to cool the pool during hot summers)
    - In-pool obstacles - benches, platforms...for the dog
    - color changing in pool lights
    - gas fire pit
    - speakers
    - Hammock spot
    - slab large enough for chlorine pump and AC
    - waterfall
    - babbling brook, probably need some height for noise abatement
    - beach entry (maybe, we have a large lot)
    - landscape lighting
    I'm interested in other ideas
    19,500gal, Gunite, Pebbletec, Chlorine, PCC2000 cleaner, Stenner Chlorine Pump, MegaCatch Mosquito Trap
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Re: New Pool: Klein, TX (no spa)
    What I've learned from the more knowledgeable on this site about UV/Ozone:
    For outdoor pools that get a lot of sun, they're not needed (you get plenty of UV from the giant fireball) and the UV system may actually cause chlorine demand to rise.
    UV and Ozone are only effective when the baddies pass through them. They do nothing for algea, bacteria, etc that exist in the pool water or cling to surfaces.
    Hope that helps and if I got it wrong, hopefully someone will be along soon to set it all straight.
    And good luck with the build. Your builder was one of our finalists and we would have been confident in their build.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    The dig is scheduled to start Tuesday.
    Aug 2014
    Houston tx
    2,524
    Please post any pics you might have of your site and design! We love pics!
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    This is off topic, but the Mega-Catch Mosquito Trap in your signature caught my eye. Does it work? We are on an acre and would love to find something effective. We also keep bees so we can't use pesticides, so this looks interesting.
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    This will be a nice one to watch. It will be interesting to see how it goes since you have already done it once before.
    Kim
    Jamie we use and love these:
    For the area we are hanging out in. It is almost as if there is a shield all around us!
    Amazon.com : OFF! Powerpad Lamp : Insects Lamp : Patio, Lawn Garden
    My husband uses this around the outside of the yard but I am not sure about it with your bees:
    Amazon.com : Black Flag 190095 40-Ounce Outdoor Propane Insect Fogger : Manual Compression Sprayers : Patio, Lawn Garden
    Kim
    JamieP's Avatar
    May 2011
    1,135
    Thank you, Kim. It's always good to get firsthand, reliable reviews of products. I'll be sure to check those out!
    Quote Originally Posted by JamieP View Post
    Jamie, yes, the megacatch works. Does it eradicate the mosquito problem...no, but it helps a lot.
    The dig started Wednesday, November 18. Here are some pictures. Thursday, they installed the plumbing for the PCC2000 in floor cleaning system.
    1118151723
    1118151723a
    1118151722_HDR
    1118151723c
    1120150713
    1120150719
    1120150720
    1120150720c
    1120150720e
    1120150722
    1120150722
    JamieP's Avatar
    May 2011
    1,135
    Progress! It looks like a really clean dig. I hope things continue to go smoothly for you.
    Thanks for the information about the mosquito trap too. One more thing to look into!
    JamieP,
    It is great to see progress. Our first build had the benefit of going through the back fence so our front yard was not damaged. At this house, that is not possible, so the yard damage is frustrating.
    They are going to do the iron work today with Gunite planned for tomorrow.
    Aug 2014
    Houston tx
    2,524
    Where is the babbling brook going to be?
    Marla
    Quote Originally Posted by Marlahoutex View Post
    Sadly, the babbling brook was a victim of budget cuts
    Aug 2014
    Houston tx
    2,524
    That's the second one that's dried up!
    Marla
    Friday they came and did the rebar, Saturday they shot the gunite. I don't have any good pictures of the re-bar as it was dark when I returned home Friday and they started the gunite at 6:20 AM Saturday morning (yes, out neighbors love us)
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    The back ledge looks a little uneven!!
    Looks great...excited I'm sure.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Here are some more updates
    Rock wall and the waterfall cove
    Pumps (Filter - Intellipro, Waterfall, then cleaner left to right), The Stenner tank and pump had not been installed when I took this picture. The electrician was out yesterday, no pictures yet. Should get started on the decking today or tomorrow.
    Jul 2012
    Tallahassee, FL
    30,535
    LOTS of work done! Nice!
    Make sure to print out a picture of you equipment and pipes to label and put up for later or just in case.
    I would also label the pipes with a sharpie or such.
    Kim
    Casey's Avatar
    SW PA
    10,448
    Nice. Love beach entries. They look so natural.
  20. Back To Top    #20
    Deck was poured Tuesday 12/15.
    The slab for the shed can be seen below:
