Thread: Removing CYA/Water
    Baton Rouge, La.
    75
    Removing CYA/Water
    I need to remove a lot of water from the pool in order to remove CYA..can someone tell me.. If I were to use a pump, How much water can I take out at a time without doing any damage to the fiberglass pool??
    Is there a "chemical" way of doing it??
    Harry
    Trilogy "Fiberglass" Pool,
    15x34 8900 gal.
    Pentair 1hp Super-Flo Pump
    Pentair CC100 Cartridge Filter, Pentair "Legend" Cleaner
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Removing CYA/Water
    If you did about 1/3 down you would be fine, that should bring you down to a more manageable number around 70 if the CYA really is 100....
    drain, refill, circulate for a few hours, retest, repeat if needed.
    The risk for fiberglass is it could pop out of the ground but I think that's if you drain more than 50% or completely....
    From a recent post on the forum there really isn't a practical/useful/efficient chemical method....
    The main issue with draining is the depth of the water table. You don't want to drain the pool below the water table level. It isn't always easy to find out the exact hight of the water table, but you should have some idea if you live in a wet swampy area or a dry well drained area and you can use that to guess. If you are up on a dry hill and there has been a drought recently you can drain much more water safely than if you live in an area with wet swampy soil and it has just rained.
    11,969
    Thanks for clarifying that. So being Baton Rouge and recent heavy rains, is 1/3 safe enough or should he just stick to skimmer level, and repeat a few times?
