Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Floc with cartridge filter?
    Sep 2015
    Gulfport
    10
    I'm told I need to use floc in my nasty cloudy green pool. How would I vacuum after the floc settles with a cartridge filter? Keep in mind I do not half the "vacuum to waste" option.
    38,475
    Re: Floc with cartridge filter?
    Welcome to TFP!
    Simple, don't use it. We do not recommend it. Who suggested you need it and why do you need it?
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,412
    Floc will gum up your cartridge if you are unable to vacuum to waste. Also all the floc may not fall out over night, requiring several vacuumings to get it all out of the pool.
    If your pool is nasty, cloudy green then it has live algae in it. You have to kill the algae to get rid of it. Floccing will not kill the algae and your pool will not clear as long as there are live algae multiplying in the water.
    What type of pool do you have?
    Love TFP? Become a
    TFP Supporter!
    Sep 2015
    Gulfport
    10
    I have a 16,000 underground. The pool has low chlorine. I added 5 lbs of shock and two hours later the shock is back down to nothing. I've tried everything!!! Cannot get pool clear and chlorine up! Am I supposed to be running full skim?
    Jun 2014
    15,221
    Jojane, let's give you some good advice to get rid of that green okay? The following step will work:
    1 - You must have the proper test kit. The proper test kit (i.e. TF-100 or Taylor K-2006) is the foundation of your pool care. Why these kits? We've learned through personal experience that you cannot reply on pool store testing, test strips, or simple over-the-counter kits. They simply do not read Free Chlorine (FC) or Cyanuric Acid (CYA) levels accurately or to the high levels we need. If you do not have a TF-100 or Taylor K2006 test kit, it should be your #1 priority.
    2 - Golden rule - Avoid the pool store for testing, advice, or many of their quick-fix products. You simply won’t get the advice/service you deserve and you will waste money on products your pool doesn’t need. Do not add anything to your pool other than what is advocated by the TFP site or its experts. You’ll have a happier pool, spend less time maintaining your pool, and probably save some $$ in the process. No more bags-of-shock!
    3 - Until you receive your own test kit, simply add one gallon of regular (generic is fine) bleach to your water each day. It won't totally clear it up, just try to keep it from getting worse right now.
    4 - Start reading the SLAM page at Pool School - SLAM - Shock Level And Maintain. This page is what will clear your algae - but you need that test kit!
    Once you receive your kit, post a full set of numbers (FC, CC, CYA, pH, TA, and CH) and we can help you better.
    Also, please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later.
    Donldson's Avatar
    NW Ohio
    2,916
    Welcome to TFP!
    Texas Splash has the right steps, I'm just here to throw in some specifics. The reason floc isn't a good idea for you is two-fold. First, it can possibly damage your filter if you don't follow the instructions perfectly. Second, it won't fix the problem. If it works it will cause most of the algae to fall to the bottom, you will vacuum it to waste (if you can't vacuum to waste then no, you can't use floc), and your pool will look better. Then the algae will grow right back because the initial problem was never fixed.
    If you haven't tried TFP then you haven't tried everything. The good news is that once you try TFP then you don't need to try anything else, because the Trouble-Free Pool Care methods work. If you follow the steps Texas Splash outlined above you will get your pool clean and if you choose to follow TFPC going forward you will not run in to this kind of problem again. I hope you give it a shot!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Sep 2015
    Gulfport
    10
    Thanks! Will do! Plan on ordering kit in the next few days. Will add bleach in the meantime!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Jo! You are on the right track now! Test kit + bleach + TFP = a clear pool!
    Let us know when you get your test kit!
    Until then take a pic of your steps looking down into your pool so we can watch your progress.
    Kim
    Sep 2015
    Gulfport
    10
    Ph- 7.6
    FC 0.3
    Alk 170
    Stabilizer 40
    Now what?
    Donldson's Avatar
    NW Ohio
    2,916
    Where did you get those results?
    From my HTC One via Tapatalk
    Sep 2015
    Gulfport
    10
    Test kit
    On the SLAM chart...the shock numbers...is that gallons of bleach?
    Donldson's Avatar
    NW Ohio
    2,916
    Whick test kit?
    Sep 2015
    Gulfport
    10
    Test strips...my kit hasn't come in yet
    38,475
    About the only thing you can do right now is: Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    The FC/CYA Chart shows the ppm of FC that you must maintain. You then use PoolMath to calculate how much bleach is required.
    I would just add a bottle of bleach every day until the kit arrives.
    Sep 2015
    Gulfport
    10
    Ok thank you. I've just noticed that I have to add my info on a computer not a phone. I will do this and then continue with bleach while I wait on the kit.
    Sep 2015
    Gulfport
    10
    Okay, I just got my kit. Logged on to TFP on my computer and looked at the Pool Calculator....Better understand how to use everything. As far as CYA goes....the pool calculator says liquid stabilizer??? Does this mean I do not use tablets anymore??
    Gulfport, Mississippi 16,000 Gallon Inground Pool, Cartridge Filter
    Jul 2012
    Tallahassee, FL
    30,585
    There are videos!!!!!!!!!!!!! Here ya go!
    JimSwim.com FAS-DPD Testing with Taylor K-2006 - YouTube
    Let us know what we can do to help!
    Kim
    Sep 2015
    Gulfport
    10
    Liquid stabilizer?
    38,475
    What is your CYA? If you need to raise it the granules are cheaper but the liquid is fine. The tablets add chlorine and CYA and lower the pH which could lead to issues and thus we generally do not recommend them.
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,585
    IF you want BUT it costs more. I use the dry stuff. Here is a link that might help you some. It has what we use in our pools.
    The tablets can cause problems as they add CYA or CH depending on what kind you have.
    Kim
